  • Banzee
    • Mar 2012
    • 189
    #976
    Originally posted by paulfromtulsa View Post
    They have been good to me. Been using them for about a year in my boats and cars . No swelling and all cells stay balanced
    Thank's for your reply , just my first time i see these lipo !!!
    • Chris VB
      • 21
      #977
      I replaced the servo with a savox because the receiver got wet too much I guess and fried, cranking the servo to one side while it was out in the lake. I got it and the gears are stripped or its cooked...didn't care. Installed my tried and true Savox which is much more responsive. Replaced the stock receiver with a futaba receiver and my 4PLS transmitter and it works mint. I love it. Won't have those problems now. :)
      • Team Lucas
        • May 2016
        • 300
        #978
        Originally posted by IRON-PAWW View Post
        Hey 36ers.
        Noted Darin's air dams back a little. Has anyone tried that and noticed results? Just trying to calm the 48's bounce and tendency to lift at speed as well. Had thought about air dams or airflow spoilers top and bottom as well. Thought I'd just ask you guys. If you think plane wings..... then I agree with Darin about placing them on top.
        yes I did when struts are level 8 + mph
        Zelos 36 stock 68 mph
        • Keagan-Z06
          • Mar 2016
          • 970
          #979
          I need to get her out to a bigger pond. I only got to hold wot for like 2 seconds but did manage to get 78.5. I feel she's got high 80s in her
          Sent from my SAMSUNG-SM-G928A using Tapatalk
          What props were you using? I updated your mph on the fast list but not sure if you running the same props?
          • paulfromtulsa
            • Nov 2013
            • 211
            #980
            Still using 447. When I can get to a big enough pond I will try some 442 and maybe a speed run with some 1915
            • Team Lucas
              • May 2016
              • 300
              #981
              working on a set of X442's now, I was informed there the same as stock SS props
              • Keagan-Z06
                • Mar 2016
                • 970
                #982
                I guess all runs is after this
                • Team Lucas
                  • May 2016
                  • 300
                  #983
                  I am running two 3s batteries more forward then the battery tray allows keeping the same weight and shifting weight forward. White foam takes place of the center batteries, so things stay tight. Putting weight to the sides more, will change turns at high speed, I don't know for the good or bad yet until this Sunday. also I suggest thin layer of foam tape on top and bottom of where the side batteries go. If your running four 3s batteries, simply take the white center foam out.IMG_1617.JPG
                  • Erroneous
                    • Apr 2016
                    • 451
                    #984
                    'Bumps mic'... This thing on?
                      I had a package arrive in the mail yesterday........
                      • ChevyPrerunner
                        • Jun 2015
                        • 205
                        #986
                        I have a few good runs today figured out that with my lipos forward on the tray the cat turns much better, maybe just me?
                        Sent from my cell using Tapatalk
                        • Erroneous
                          • Apr 2016
                          • 451
                          #987
                          3 coats of primer on. Bumpsand next with 800 and on to shooting color. image.jpg Hatch is allready done. image.jpg
                          • Team Lucas
                            • May 2016
                            • 300
                            #988
                            Originally posted by erroneous View Post
                            3 coats of primer on. Bumpsand next with 800 and on to shooting color. [ATTACH=CONFIG]145025[/ATTACH] hatch is allready done. [ATTACH=CONFIG]145026[/ATTACH]
                            sweeeeet!
                            • shua
                              • Apr 2015
                              • 479
                              #989
                              And.......
                              • Banzee
                                • Mar 2012
                                • 189
                                #990
                                Originally posted by Erroneous View Post
                                3 coats of primer on. Bumpsand next with 800 and on to shooting color. [ATTACH=CONFIG]145025[/ATTACH] Hatch is allready done. [ATTACH=CONFIG]145026[/ATTACH]
                                Awesome color !!!
