Originally posted by paulfromtulsa
View Post
I replaced the servo with a savox because the receiver got wet too much I guess and fried, cranking the servo to one side while it was out in the lake. I got it and the gears are stripped or its cooked...didn't care. Installed my tried and true Savox which is much more responsive. Replaced the stock receiver with a futaba receiver and my 4PLS transmitter and it works mint. I love it. Won't have those problems now. :)
yes I did when struts are level 8 + mphOriginally posted by IRON-PAWW View PostHey 36ers.
Noted Darin's air dams back a little. Has anyone tried that and noticed results? Just trying to calm the 48's bounce and tendency to lift at speed as well. Had thought about air dams or airflow spoilers top and bottom as well. Thought I'd just ask you guys. If you think plane wings..... then I agree with Darin about placing them on top.Zelos 36 stock 68 mph
What props were you using? I updated your mph on the fast list but not sure if you running the same props?Originally posted by paulfromtulsa View PostI need to get her out to a bigger pond. I only got to hold wot for like 2 seconds but did manage to get 78.5. I feel she's got high 80s in her
Sent from my SAMSUNG-SM-G928A using TapatalkProboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
I am running two 3s batteries more forward then the battery tray allows keeping the same weight and shifting weight forward. White foam takes place of the center batteries, so things stay tight. Putting weight to the sides more, will change turns at high speed, I don't know for the good or bad yet until this Sunday. also I suggest thin layer of foam tape on top and bottom of where the side batteries go. If your running four 3s batteries, simply take the white center foam out.IMG_1617.JPGZelos 36 stock 68 mph
I have a few good runs today figured out that with my lipos forward on the tray the cat turns much better, maybe just me?
Sent from my cell using Tapatalk
