  • Erroneous
    • Apr 2016
    • 451
    #1021
    With the cable in hand turn it the same direction the motor would (prop tops toward each other). The cable should be wanting to tighten on it self and spiraling downwards toward the props. R labled shaft should be on the left of boat being the right hand rotating shaft. If the cable has been turning backwards, I would change the teflons out. They have been cooked.
    • Keagan-Z06
      • Mar 2016
      • 970
      #1022
      Son of *****! I should of known from the last time I asked about the X447s with one being labelled X447R, at first I had it on the right, then was corrected to be on the left. Now here we are a few weeks later and I do a dumb move! Will swap them when I get home. I should be going back to the lake tomorrow, hopefully I have it sorted out by then. Thanks Erroneous!
      • Erroneous
        • Apr 2016
        • 451
        #1023
        Just shows how tough the upgrade cables are. No prob. This is why I love this forum.
        • Team Lucas
          • May 2016
          • 300
          #1024
          Its one of those things that have been lingering in the back of my head since some suggestions started popping up. When I bought the OSE HD flex, one came labeled (R) assuming this is right hand cable. Thats where it went. Any other way to know if its in the correct shaft?
          rotate them inward and the flex shaft will coil downward, like a screw thread, but been reading about your problem lately and if you have flex shafts switched, one would think the other shaft would be doing same thing, since that one would be switched as well, unless you have 2x (r) or (l) shafts.
          Zelos 36 stock 68 mph
          • Team Lucas
            • May 2016
            • 300
            #1025
            Ran the new battery configuration today by placing the two 3s batteries down in the sides and forward about 1". Lost speed, but it turned better. Not worth the trade off. Running stock with struts level, and wants to blow over at upper 60's. Going back to center mount pushed forward and will start adjusting struts.IMG_1634.jpg also lost speed from the detounged 447's and down to 442's.
            • Keagan-Z06
              • Mar 2016
              • 970
              #1026
              I know, learn a lot as newbie to RC boats here.
              • Keagan-Z06
                • Mar 2016
                • 970
                #1027
                That would certainly suck! Lets hope not! There is grease coming up a bit on the other side as well, just not as much as the other. My dad already swap them in a haste. Lol! Im stuck at work so I don't know what just took place at home.
                • Keagan-Z06
                  • Mar 2016
                  • 970
                  #1028
                  Ran the new battery configuration today by placing the two 3s batteries down in the sides and forward about 1". Lost speed, but it turned better. Not worth the trade off. Running stock with struts level, and wants to blow over at upper 60's. Going back to center mount pushed forward and will start adjusting struts.[ATTACH=CONFIG]145413[/ATTACH] also lost speed from the detounged 447's and down to 442's.
                  Is that speed with Stock props and motors? What are you using to hold the GPS in place at that location? Velcro? I also noticed speed loss with detounged x447s.
                  • Keagan-Z06
                    • Mar 2016
                    • 970
                    #1029
                    Bat outta hell! It was after this wild ride a motor went into limp mode. My gf caught this at the right moment!
                    • Team Lucas
                      • May 2016
                      • 300
                      #1030
                      sorry if I worded it wrong, I lost speed with the 442's. keeping the 447's on until back ordered shafts get it. Stock motors and esc's, drives level. GPS is held in with zip ties . I drilled holes in battery plate to zip tie tight
                      • Keagan-Z06
                        • Mar 2016
                        • 970
                        #1031
                        From what I understand the 442s are basically like stock props? The 447s I thought were heating up my stuff more until smoke but now I know the smoke is of another source. Might throw them back on for a quick 1-2 burst. I have on one of those floaty things on my GPS but haven't found a way to secure it.
                        • rcboone2000
                          • 83
                          #1032
                          Check the rotation of the motors the should tighten the spiral of the shafts
                          • Keagan-Z06
                            • Mar 2016
                            • 970
                            #1033
                            Still stuck at work, will check all possibilities in the next hr or two. Thanks guys, will report back soon.
                            • DannyD
                              • 6
                              #1034
                              Anyone add a water pump yet?
                              • Keagan-Z06
                                • Mar 2016
                                • 970
                                #1035
                                I think kfx and a couple others were trying it. Check his water inlet thread.
