  • Keagan-Z06
    • Mar 2016
    • 970
    #541
    I think I found one of my problem.
    • shua
      • Apr 2015
      • 479
      #542
      The red wire should be removed from one of the esc's. That is to keep the bec from one esc from backfeeding the other esc.
      • Erroneous
        • Apr 2016
        • 451
        #543
        image.jpg These two tools are worth their weight in gold. Saved me a ton many times with rc projects.
        • Keagan-Z06
          • Mar 2016
          • 970
          #544
          So having that wire not connected is normal??
          • shua
            • Apr 2015
            • 479
            #545
            On mine the "Y" harness connecting the two esc leads to the receiver has the red wire removed from one of the esc connectors. In your pic it appears that you may have broken wire on the esc side of the connection. It is hard to tell. If so then you could connect that esc lead to the side of the "Y" harness that already has the red wire removed and it should work fine.
            • Keagan-Z06
              • Mar 2016
              • 970
              #546
              Here is another pic. The broken wire is more towards the back of the boat that leads to the receiver. It's on that end that it's broken.
              I must almost mention the middle of that connector the red wire came from doesn't have a pin. It's empty!
                This. You only need one power from one esc.
                  Three coats of clear this evening before sun went down. After that the bugs would be out. Soon as I was done with coat three, the lights were turned out and shop locked. I snapped a pic right before. I just can't pick up the color correctly in this light. It's so beautiful.
                  • gohan
                    • Jun 2011
                    • 495
                    #549
                    Nighty Night Sweet One...Sweet Dreams of 90+ Mph !!
                    • Keagan-Z06
                      • Mar 2016
                      • 970
                      #550
                      So disregard that wire?
                      • Keagan-Z06
                        • Mar 2016
                        • 970
                        #551
                        That is a thing of beauty!
                          Listen to me. You have two escs, right? Then that means you have a power wire from each one. Then they go into a "y" connector. If one power wire in the y connector isn't clipped then they will feel power into each other. Might not hurt but proper practice it to not back feed them...so you only need power from ONE ESC going into the receiver.
                          • Erroneous
                            • Apr 2016
                            • 451
                            #553
                            Sunlight will wake it right up. Looks like it has a gold undertone. Any opinions on colorshift?
                            • Keagan-Z06
                              • Mar 2016
                              • 970
                              #554
                              Ok Thanks for explaining to the slow guy. Appreciated
                              • Team Lucas
                                • May 2016
                                • 300
                                #555
                                That's going to look sweet with black Zelos decals
                                Zelos 36 stock 68 mph
