Are u referring to the bsi epoxy from horizon? I will do that when I'm done silicone all the bolts n stuff. Since water seems to be getting in anyhow. Would the recent prop changes cause any of this?
Thats a lot of water your taking in. Did you do a bathtub test? Did you take off all the hardware and seal with silicone? Pressure check cooling lines?Originally posted by Keagan-Z06 View Post[ATTACH=CONFIG]143828[/ATTACH]
That's the amount of water she takes in. Yes canopy taped. Two times on Sunday three times on Wednesday!
Is the water collecting in both sides??Darin E. Jordan - Renton, WA
Currently taking her apart as we speak. Planning to silicone the nuts and bolts. Then will do a submerged test.Originally posted by Mxkid261 View PostThats a lot of water your taking in. Did you do a bathtub test? Did you take off all the hardware and seal with silicone? Pressure check cooling lines?Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
Any tips on how to get back on nuts and washers from inside the boat. Taking off although time consuming was easy but putting back on can be quite a PITA. LolProboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
I use a pair of snapring pliers as they are spring loaded. The are like needlenose pliers but in reverse.Originally posted by Keagan-Z06 View PostAny tips on how to get back on nuts and washers from inside the boat. Taking off although time consuming was easy but putting back on can be quite a PITA. Lol
Managed to do the same with a regular needle nose pliers. A bit of pain but im getting there. One more strut left and I'm done.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
Done! Whew!! That is not something I wanna do again! All hoses are fine. No leaks from those. I had a little gap (very small) under both struts where it meets the back pad. Dropped a bit of silicone around that area too. My dynamite packs finish charging as well and one of the packs read C1- 4.19, C-2- 4.20, C-3- 4.14. Can I run it that way still? I'm also thinking of putting on back my original props until I figure out what else was causing all that erratic behavior today. I don't think the Octuras were the cause. I know at one point both ESCs were giving me a 2s reading. Had it autocalculate and registered for 3s. At that time I'm not sure how low the packs were to be giving me 31mph which I find strange. Both times I brought the boat in, I had the red light on one ESC which is the new one. Unplug and power on again and they both do 3s beeps and green.Proboat Voracity-E 36" , Proboat Zelos 36 Twin , Proboat Miss Geico 29" , Traxxas Spartan, Fightercat Daytona, Zonda
