Is anyone else having problems with the motor shutting down about every 30 to 40 feet.My battery is fine I've checked that I've changed speed control no change I finally changed the stock prop to a m220 with that prop it will run a full battery no shut downs.We have 3 boats they are all doing the same thing.
NEW Pro Boat RECOIL 26" Self-Righting!!
Which receiver did you use ? My boat was also losing range at only maybe 50 feet and HH sent me a ecx13003 receiver as a replacement. Is that good for at least 200 or more feet if I get as much antenna out of the boat as I can ?Originally posted by rcdrivertim View PostRafael, I put the new receiver in. MAJOR difference in range. I can drive much further now. Makes the boat more fun to drive. Looking at a 3S 5000 but I am concerned about the self righting working right. I don't wanna lose it.
Thanks much!
Has anyone else have issues with 50 feet or so total range ? Does the replacement one HH sends out when you call them solve the problem or do I just have to relocate it higher in the hull to get more of the antenna exposed ?Originally posted by stony30 View PostWhich receiver do you get ? Stock one ?
? I am looking to get a recoil 26. I kmow they go about 30mph stock. Im looking to upgrade the motor and prop and want to run around 40mph which I hear is about the limit for this hull. I have a 5000mah , two 3850mah and two 3300mah packs that ibwill be using. Can someone recommend a motor (Leopard) and water jacket and prop that will get around 40mph (part numbers please) I will be running stock esc first then ipgrade if necessary. I am goung to install the larger trim tab fins from stealthwake to help stability. Any ideas?
I'm getting 38 mph out of mine with the stock motor and a 120 amp speed control with a x 642 prop and a 3600 ma 50c battery.The boat will still self rite.The recoil is more fun than all of my fast boats
