NEW Pro Boat RECOIL 26" Self-Righting!!
  • Darin Jordan
    • 9446
    Not to be overlooked...
    Recoil 26-inch Self-Righting Deep-V BL:RTR
    Features
    Capable of reaching speeds of 30+ mph
    Self-righting hull system keeps you from going belly-up
    Water-cooled 2100Kv brushless motor and 60-AMP Dynamite® ESC
    11.1V 3200mAh 3S LiPo and LiPo balance charger included
    Includes Pro Boat® 2.4Ghz marine radio system
    Waterproof electronics
    Injection molded radio tray
    Aluminum rudder with stainless trim tabs
    Stainless steel hardware
    Flex shaft with Teflon liner
    Composite molded 2 blade propeller
    Specifications
    Length:
    26 in (660.4mm)
    Beam:
    7.9 in (200mm)
    Motor Size:
    2100Kv 14-Pole Brushless Outrunner Marine Motor, 33mm X 42mm
    Weight:
    3 LB (1.4 KG)
    Speed:
    30+ MPH
    Radio:
    2.4GHz 2-Channel Surface Transmiter
    Speed Control:
    60A BL Marine ESC 2-3S
    Hull Material:
    Blow Mold ABS
    Trim Scheme Colors:
    Yellow/Orange
    Prop Size:
    1.34 x 2.06
    Hull Type:
    Battery:
    11.1V 3200mAh 3S 30C LiPo
    Kit/RTR:
    RTR
    Drive System:
    Flex Shaft
    Is Assembly Required:
    No
    Darin E. Jordan - Renton, WA
  • Rafael_Lopez
    • Jan 2015
    • 470
    Some behind the scenes bashing video. Max speed, in stock trim, at the end of the video.
    Rafael Lopez
    Product Developer-Pro Boat
    • Rafael_Lopez
      • Jan 2015
      • 470
      I know there isn't as much excitement about this boat as the Twin, but it's a real fun "basher" boat. I'm actually going to the beach with it this weekend to launch it off, and surf the waves. I'll make sure to post a video.
      Rafael Lopez
      • Rafael_Lopez
        • Jan 2015
        • 470
        The Recoil 26 is a very versatile boat.#HowDoYouLaunchYourBoat
        And some rough water/beach fun.
        Rafael Lopez
        • 98Corvette
          • Feb 2016
          • 10
          Any update on when it will be available? I am looking forward to buying one. I have a Joysway Offshore Infinity and it is a blast but it's trashed and I need a replacement self righting boat.
          • Rafael_Lopez
            • Jan 2015
            • 470
            The boat is still on schedule to start shipping the second week of March.
            If anything changes well update the first post.
            Rafael Lopez
            • rcdrivertim
              • Mar 2016
              • 17
              Got mine. Love it. It is very stable! Wish I would get more run time. Also want to know if the motor can be changed seeing as the boat has a 60amp ESC. If it can would it handle a 4S? Hope some people put comments here and upgrades done.
              • Mitch S
                • Jan 2016
                • 47
                I've had mine for nearly a month now as well. Having some transmitter issues, but it will be fine.
                I'm really enjoying the boat. I took the weighted coupler out and running 3s, 5000mah and its fun, with some good run times. Self righting feature works like a charm.
                That being said, I'd be interested in some upgrades as well, looking for some larger trim tabs and fins
                • Darin Jordan
                  • 9446
                  Are you saying that the self-righting works WITHOUT the weighted coupler?? Stock motor still??
                  Curious, because I have done a pretty CRAZY upgrade experiment with my Recoil, having never actually driven it stock, and am about to test it today. I replaced the motor and ESC (well, all the electronics, actually) with a system suited for NAMBA N2-Offshore (2S Lipo, 3500-ish KV motor, etc.), but I retained the weighted coupler.
                  Would be interested to know more about your setup.
                  • Rafael_Lopez
                    • Jan 2015
                    • 470
                    [B]Are you saying that the self-righting works WITHOUT the weighted coupler?? Stock motor still??[\B]
                    Darin, he says he removed the coupler and is using a full size pack with the stock motor. It will not self-right with a full size pack and an inrunner.
                    The stock electronics, both ESC and motor, will not work with voltage higher than 3s. The ESC will not arm and if you install a different ESC the motor will literally burn up. There is a bit of room to prop up, but I'd stay away from props larger than 43-44mm with pitch greater than 1.6. This isn't a performance boat so I didn't do much prop testing. What I can tell you is that the ESC is more than enough for the stock motor with the stock prop, 1.6x1.6. The largest prop I tested with was an x442 and it ran well with no issues, but no major speed gains. If you over prop, the ESC will amp out before it burns up, or at least that's what is is programmed to do. The hulls speed limit is +/- 40mph. Any more than that and the boat will chime walk due to too much hull out of the water and the trim tabs being to far out of the water. One would have to install another set of tabs closer to the keel to try and settle it down, and probably larger turn fins. I got one over 40mph with a 2000kv inrunner and a 90A ESC on 4s, but didn't like the way it drove; I never added trim tabs lower to the keel.
                    Rafael Lopez
                    • Darin Jordan
                      • 9446
                      Awww... got it. I'll have to see if it'll self-right with this setup:
                      • Rafael_Lopez
                        • Jan 2015
                        • 470
                        I could not get it to self right with a 2000kv motor on 3s with the weighted coupler. Even with a 5000mah pack.
                        Rafael Lopez
                        • Darin Jordan
                          • 9446
                          This is a 3500KV motor... :) We'll see... That's why we test.
                          • Darin Jordan
                            • 9446
                            It won't be the end of the world for my purposes if it won't self-right... it WILL be if it SELF-FLIPS, though...
                            • Mitch S
                              • Jan 2016
                              • 47
                              You've got Raphaels reply, but I'll give you mine any way.
                              I run the stock battery and a larger 5200mah. I've been able to have it self right with both batteries without the coupler, However, it does take more effort with the smaller pack.
                              idk, for me, the boat is fast enough to have fun with. I really have no desire to go faster with it. I do, however, want to find larger trim tabs and fins. Maybe it wont spin as easy, If anyone has a suggestion on tabs and fins, please let me know.
                              FYI, the stock motor runs to about 125 degrees on mine. Anyone else have any temp readings??
