Supervee27 ?
  • wizard122
    • 483
    #61
    By the way I forgot to tell you if you want your push rod for the rudder to be SS go to a bike shop and buy SS spokes it should be th same size as the stock one the threads match just bend and cut much stronger too.
    2 SV 27's and Vac-U-Pickle UL-1 Power
    • rchippie
      • Jan 2010
      • 567
      #62
      Flex shaft
      I m getting ready to take out the flex shaft on my sv 27 for the first time & re lube it & i have a couple of ?'s. There is only about 1mm - 2mm of spacing between the stuffing tube & collet . Is it okay to cut a liitle of the stuffing tube so it will be eaiser to re-insert the flex shaft back into the collet ?.
      • wizard122
        • 483
        #63
        Motor Mount
        I don't see why not. If you haven't already got everything centered you should be ok. I changed my motor mount so i didn't have to deal with those small nuts too much work when your all ways tuning your boat.
        I'm not running water through it as it was a little restricted.
        But the mount works great with out it.
        • wizard122
          • 483
          #64
          Strut Bushing
          Sorry forgot to tell you only lube cable at strut end not the cable end causes a lot of drag. I had to put a drop of CA on strut bushing just at the end keeps the bushing from spinning in stuffing tube only takes a drop and lube the part that has the holes in it works great and low drag. Also remove blue stinger first you don't want any glue on there.
          • domwilson
            • 4405
            #65
            You want to lube the entire shaft on these. The lube not only lubricates the shaft, stuffing tube. But it also acts as a barrier to prevent water intrusion up the tube shaft. Not to mention, it minimizes rust. The amount of drag lube causes is negligible.
            Dragboat Boat did some tests a while back on various lubes.
            Government Moto:
            • rchippie
              • Jan 2010
              • 567
              #66
              Well the mantanice has been done & i installed a cf 45 prop. I just ran the boat with the new prop the temp went up . After a full pack my motor was 145 at the endbell & 115 on the motor jacket & the lipo's were 108 . Is that still okay ?.
                • 9479
                #67
                How long was your run, and how much did you put back into your packs?
                • rchippie
                  • Jan 2010
                  • 567
                  #68
                  My run was between 8 - 10 min. I have not rechargd the lipo's yet. But they were at 3.60 when i checked them . Im running neu 25c 4900's. The air temp was mid 70's.
                    • 9479
                    #69
                    are you running the stock cooling?
                    • rchippie
                      • Jan 2010
                      • 567
                      #70
                      Im using the stock rudder pick up with a after market aluminum water jacket .
                        • 9479
                        #71
                        ok, to me your temps seem a little high..
                        have you opened the pickup in the rudder some?
                        I used a point file to open mine
                        • rchippie
                          • Jan 2010
                          • 567
                          #72
                          Yes i did. Those temp are with the CF45 prop & not the stock prop. with the stock prop the temps are great .
                            • 9479
                            #73
                            well your temps are ok, but when I run a CF45 and CF48 my motor temps only get to 105* and 115*, esc is 95* and batteries are 90-95*
                            • rchippie
                              • Jan 2010
                              • 567
                              #74
                              I wonder if im running it to wet & thats why my temps are a little higher .
                                • 9479
                                #75
                                Yes that could be the very reason..
