Supervee27 ?
    • 9479
    #91
    Well every thing sounds ok?
    your temps are not to high as to damage anything..
    have you greased the shaft?
    • rchippie
      • Jan 2010
      • 567
      #92
      Yes i have done it once . But i need to do it again as i have ran the boat at least 4 times since i greased it .
      • Ctonez
        • Jul 2007
        • 404
        #93
        If the boat is gonna sit overnight after a run you really should pull the shaft, clean, dry and regrease before running again.
        After a race day, I bring all the boats home, remove all the shafts, and leave the boats open to completely dry. I store all my drive shafts in a metal spackle trough and spray down with Corrosion-X. They all sit in a Corrosion-X bath in the bottom of the trough until I need to install them again. Then I just wipe off, add grease, and install for a days worth of racing. I still have the stock shaft in my SV after racing it for 3 seasons.
        Got this tip from "The Snowman" when I was just starting out...I've never had a shaft fail, never needed to replace a shaft. Thanks Brian!
        • Ctonez
          • Jul 2007
          • 404
          #94
          Sorry I'm late to chime in...
          The temps are fine if you're running for 10 min.
          I highly advise opening the hole on the rudder inlet slightly.
          I did that and added larger ID tubing throughout and I don't see anything over 115 after a race heat (approx. 5 min.).
          • rchippie
            • Jan 2010
            • 567
            #95
            I have all ready done eveything you mentioned . m going to the lake latter i'll bring a stop watch if if remember . So i can acctually time how long i run . I put the stock prop back on. I'll do my noraml run & see if the temps are lower. I had enough speed with the stock prop before. Thank you for the tips.
            • rchippie
              • Jan 2010
              • 567
              #96
              I ran my boat today with the stock prop.The temp went back to mormal 95 on the water jacket & 115-120 on the open end bell . the speed felt the same . But it took a tad longer to get on plane.
              • Ctonez
                • Jul 2007
                • 404
                #97
                If you do want to get another prop - our club runs the Grimracer 42x55 prop in our spec-SV class. It gets the boat on plane much better than the stock prop and gives a bit more speed as well.
