Supervee27 ?
  • wizard122
    • 535
    #76
    Hi try moving you batteries back a little that may help. What has your COG?
    2 SV 27's and Vac-U-Pickle UL-1 Power
    • Diesel6401
      Memento Vivere
      • 4391
      #77
      Originally posted by rchippie View Post
      Im using the stock rudder pick up with a after market aluminum water jacket .
      I use dual pickup and temps are never an issue for me so maybe you should try something like this.
      - Diesel's Youtube
      - Diesel's Fleet
      • Diesel6401
        Memento Vivere
        • 4391
        #78
        I use just a standard transom pickup found here on ose for my motor
        - Diesel's Youtube
        - Diesel's Fleet
        • domwilson
          • 4411
          #79
          I wonder if im running it to wet & thats why my temps are a little higher .
          Do you have pics of the back and sides of your setup? Especially the back end. Also pics of the inside with your batteries in their running position would help.
          Government Moto:
          • rchippie
            • Jan 2010
            • 640
            #80
            I did slide my lipo's farther foward than i normally do . so i will move them back a little & try again . If that does not bring the temps down. then i will install the trim tab water pick up i have have & then try again. thank's for the help.
              • 9481
              #81
              I think I run my batteries about 2"- 2 1/2" forward of the motor mount..
              • BondoBrushless
                • Feb 2010
                • 156
                #82
                Whats up Mike, small world to see you here too ?
                Havin' fun w/your Vee ?
                I'm going to convert my 48" or buy my buddy's 40" to build but thinking of another SuperVee myself to play with in the mean time during assembly ?
                Where do you run yours at in Largo ?
                Bondonutz
                • rchippie
                  • Jan 2010
                  • 640
                  #83
                  Bondonutz
                  There is a lake off starkey road & brian dairy rd .
                  • BondoBrushless
                    • Feb 2010
                    • 156
                    #84
                    I herd of it, back behind the medical place right ??
                    • rchippie
                      • Jan 2010
                      • 640
                      #85
                      I heard of it, back behind the medical place right ??
                      Yes thats it .
                      • BondoBrushless
                        • Feb 2010
                        • 156
                        #86
                        If weather permits Your more than welcome to join us Sunday ? There was about 15+ guys out at our little lake last Sunday and had a great time. One of the fellas has a Kayak and we set up markers. I should be receiveing my Vee Friday,anxious.
                        When I had my last Vee I didn't hang out with anyone whom ran boats, now theres a bunch of guys so it should be more fun this time around.
                        You have my #, gimme a call if interested
                        • rchippie
                          • Jan 2010
                          • 640
                          #87
                          another temp ?
                          As i stated before i went to a cf45 prop with the enlarged stock rudder pick up & the temps were 115 on the water jacket & 145 on the open endbell & 108 on the lipo's . I then tried the trim tab pick up only & the temp's stayed the same . Today i used both pick up's together & the temps stayed the same . The lipo's are about 1 3/4 inches past the motor mount . Any idea's ?. I was thinking i may go back to the stock prop as the speed seems the same with this prop . But the boat gets on a plan quicker with the cf 45 prop . This temps are after appromimently a 8 - 10 min run.
                          • wizard122
                            • 535
                            #88
                            My boat ran like that also. My favorite prop is GrimRacer 40/52X3 runs cooler and very fast 39.4 mph
                            also try running your lipos farther back till it gets loose then move them back alittle post some more pics.
                              • 9481
                              #89
                              how much are you putting back into your packs after your runs?
                              I run a CF45 and CF48 for about 6-7min and my temps are much lower than yours..
                              also it sounds like my batteries are placed like yours to
                              • rchippie
                                • Jan 2010
                                • 640
                                #90
                                Im not sure as i did not look at that before i disonnected the lipo'd from the charger. Im, pretty sure it's over 2600. My packs are neu 25c 2s 4900's The pack was close to the lvc when i stopped, if that helps.
