I do not have anypics of the prop trying to fit on, I will try and get some today. What where some of the issues with the electric KOS? I've read nothing but good things about the FASTech as well, I'm just not the biggest fan of Proboat and I've heard mixed reviews of the Widowmaker. One thing I noticed in all the vids of the FASTech is how stable it looks in the water at top speed, widowmaker seems to bounch around alot. I do like the single battery operation on the WM though.
Rio EP my thoughts
I'll give it a try without over torque. The nut maybe able to sit flush and maybe a little locktight will help.Originally posted by SweetZ28 View PostI did not mean compress it I meant that they sometimes push on a little more than when you just slide it on by hand and you can actually fit it on .
Hi if it goes on as far as you say you are fine.Originally posted by Diesel6401 View PostI'll give it a try without over torque. The nut maybe able to sit flush and maybe a little locktight will help.
I'll put it on and put some pics up so you can see it.Originally posted by SweetZ28 View PostHi if it goes on as far as you say you are fine.
If you can get the nut to sit flush it will work fine...
Should I Still use locktight?Originally posted by Brushless55 View PostIf you can get the nut to sit flush it will work fine...
You can but bairly put some on don't use alot only a little is needed.Originally posted by Diesel6401 View PostShould I Still use locktight?
I'm not sure if locktight works with this because it has a plastic insert..
I would'nt worry about it, I don't use any and I have not lost a prop!
Originally posted by Brushless55 View PostI did some runs yesterday and tried the stock prop on 2s then on 3s, then tried a y535 on 3s, then a CF48 on 2s then on 3s..
I meant to try my a s220 but totally forgot about that prop..
best speed was the CF48 on 3s and that only got me 19mph..
I'm going to try a Team Orion Revolution 13x1 on 2s with the y535 and see how that works
RIO has a 1/8 shaft dia?
I think the prop does?.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
CF props only come in 4mm, that prob as close as im going to get.
I have an adapter that I useOriginally posted by Diesel6401 View PostCF props only come in 4mm, that prob as close as im going to get..NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
You can use a brass pipe 2 sizes and make a adaptor to fit the 3/16 CF props.Originally posted by Diesel6401 View PostCF props only come in 4mm, that prob as close as im going to get.
Good Idea ZOriginally posted by SweetZ28 View PostYou can use a brass pipe 2 sizes and make a adaptor to fit the 3/16 CF props..NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Thanks but Steve has it shown ho to make one on his site here:Originally posted by Brushless55 View PostGood Idea Z
http://www.offshoreelectrics.com/inf...propellers.php
