Rio EP my thoughts
  • Diesel6401
    Memento Vivere
    • 4391
    #136
    I do not have anypics of the prop trying to fit on, I will try and get some today. What where some of the issues with the electric KOS? I've read nothing but good things about the FASTech as well, I'm just not the biggest fan of Proboat and I've heard mixed reviews of the Widowmaker. One thing I noticed in all the vids of the FASTech is how stable it looks in the water at top speed, widowmaker seems to bounch around alot. I do like the single battery operation on the WM though.
    - Diesel's Youtube
    - Diesel's Fleet
    • Diesel6401
      Memento Vivere
      • 4391
      #137
      Originally posted by SweetZ28 View Post
      I did not mean compress it I meant that they sometimes push on a little more than when you just slide it on by hand and you can actually fit it on .
      I'll give it a try without over torque. The nut maybe able to sit flush and maybe a little locktight will help.
      - Diesel's Youtube
      - Diesel's Fleet
      • SweetZ28
        • 1535
        #138
        Hi if it goes on as far as you say you are fine.
        WWW.PPRSLOTS.COM
        • Diesel6401
          Memento Vivere
          • 4391
          #139
          I'll put it on and put some pics up so you can see it.
          - Diesel's Youtube
          - Diesel's Fleet
            • 9481
            #140
            If you can get the nut to sit flush it will work fine...
            • Diesel6401
              Memento Vivere
              • 4391
              #141
              Should I Still use locktight?
              - Diesel's Youtube
              - Diesel's Fleet
              • SweetZ28
                • 1535
                #142
                You can but bairly put some on don't use alot only a little is needed.
                WWW.PPRSLOTS.COM
                  • 9481
                  #143
                  I'm not sure if locktight works with this because it has a plastic insert..
                  I would'nt worry about it, I don't use any and I have not lost a prop!
                  • Diesel6401
                    Memento Vivere
                    • 4391
                    #144
                    I did some runs yesterday and tried the stock prop on 2s then on 3s, then tried a y535 on 3s, then a CF48 on 2s then on 3s..
                    I meant to try my a s220 but totally forgot about that prop..
                    best speed was the CF48 on 3s and that only got me 19mph..
                    I'm going to try a Team Orion Revolution 13x1 on 2s with the y535 and see how that works
                    RIO has a 1/8 shaft dia?
                    - Diesel's Youtube
                    - Diesel's Fleet
                      • 9481
                      #145
                      I think the prop does?
                      • Diesel6401
                        Memento Vivere
                        • 4391
                        #146
                        CF props only come in 4mm, that prob as close as im going to get.
                        - Diesel's Youtube
                        - Diesel's Fleet
                          • 9481
                          #147
                          I have an adapter that I use
                          • SweetZ28
                            • 1535
                            #148
                            You can use a brass pipe 2 sizes and make a adaptor to fit the 3/16 CF props.
                            WWW.PPRSLOTS.COM
                              • 9481
                              #149
                              Good Idea Z
                              • SweetZ28
                                • 1535
                                #150
                                Good Idea Z
                                Thanks but Steve has it shown ho to make one on his site here:
                                http://www.offshoreelectrics.com/inf...propellers.php
                                WWW.PPRSLOTS.COM
