Rio EP my thoughts
  • Diesel6401
    Memento Vivere
    • 4391
    #181
    Originally posted by Rumdog View Post
    If you're buying a package (esc and motor) you'd be much better suited buying one made for boats. You'll get a water-cooled esc. You could get yourself a feigao 540 s motor and run a sv27 esc for fairly cheap. It would be overkill, but you could run the whole sv27 package in this hull. Keep in mind, lower kv, higher voltage will be much more reliable than high kv and lower voltage. If any of you guys need a smallish 3s lipo, I have one listed in the swap shop for $20.00 bucks.
    I kinda wanted to get it to one battery in the hull, that's why I liked the WM setup. Any suggestions to which exact motor would be best ?!?!?! I'm also running NIMH and don't wanna go lipo
    - Diesel's Youtube
    - Diesel's Fleet
    • SweetZ28
      • 1535
      #182
      I tried 3300KV to slow I say the vxl 3500KV will be a good motor.
      WWW.PPRSLOTS.COM
      • Rumdog
        • 6667
        #183
        Just curious, why no lipo?
        • Rumdog
          • 6667
          #184
          The Feigao 8 or 9s would work well with 7.2 volt nimh. kv x volts equals rpm. Shoot for 30-35k rpms.
          • SweetZ28
            • 1535
            #185
            The S cans are short won't they not have a lot of tork like the traxxas long can VXL?
            WWW.PPRSLOTS.COM
            • Rumdog
              • 6667
              #186
              For the Rio ep, you would only need a S size can. The larger motors will have too much physical mass for that hull and may hinder the handling. You could use an L size can, but it's unnecessary.
              • Diesel6401
                Memento Vivere
                • 4391
                #187
                I already have money in nimh batteries and the charger I have is a great charger, but it's not for lipo's. The big reason is I just run boats by myself for fun and I don't need to worry about LVC and charging/storing my batteries a major deal. NIMH are just way easier and suit my application way better. Who knows I may switch sometime down the road, but for now I'm happy.
                - Diesel's Youtube
                - Diesel's Fleet
                • Diesel6401
                  Memento Vivere
                  • 4391
                  #188
                  http://www.hobbyking.com/hobbycity/s...dProduct=10331
                  http://www.offshoreelectrics.com/pro...?prod=fei-540S
                  8s
                  You guys think this is ok?
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • Rumdog
                    • 6667
                    #189
                    On ebay type in seaking esc. The 60 amp is VERY affordable and waterproof/watercooled.
                      • 9481
                      #190
                      The stock motor in these little hulls is a 550, so it would be the same as the L cans..
                      • Rumdog
                        • 6667
                        #191
                        AHHH sweet! that does leave more options.
                        • Diesel6401
                          Memento Vivere
                          • 4391
                          #192
                          This is what i'm thinking for my RIO:
                          http://cgi.ebay.com/HOBBYWING-Seakin...item2a025cae34
                          http://www.offshoreelectrics.com/pro...?prod=fei-540L
                          6L (4116kv)
                          On my batteries that i run i should reach between:
                          29,635rpm on my 7.2v nimh and about 34,574rpm with my 8.4v nimh. Sound ok?
                          - Diesel's Youtube
                          - Diesel's Fleet
                          • SweetZ28
                            • 1535
                            #193
                            6L (4116kv)
                            I don't know i think that's way to muchKV i would stay 35 to 37KV.
                            WWW.PPRSLOTS.COM
                            • Diesel6401
                              Memento Vivere
                              • 4391
                              #194
                              What could happen if I have to much rpm?
                              - Diesel's Youtube
                              - Diesel's Fleet
                              • SweetZ28
                                • 1535
                                #195
                                I tried my novak 4300 and it stunk it reved way to much you would have to use a really small prop I think i tried a 38 or 35mm prop and it was slow because it reved so much you would need even way smaller of a prop...and also on NIMH packs the more KV the more strain and heat on all parts and battery packs.
                                WWW.PPRSLOTS.COM
