Motor upgrade
  • Diesel6401
    Memento Vivere
    • 4391
    #46
    Originally posted by Rumdog View Post
    I fit that esc into a vacu-pickle, but it was a tight fit. It is probably too tall for the ul-1.
    I'll stick to the 120a whenever I get some more cash.
    - Diesel's Youtube
    - Diesel's Fleet
    • Diesel6401
      Memento Vivere
      • 4391
      #47
      Originally posted by ncornacchi View Post
      I've got a Fieago 7XL, 2370KV with Etti 150 and Grim 57/3 in the UL1 and it runs like a charm. But IMO, the Nue 1515Y with Woltz .078" wire drive, M440 and the CC240 is the way to go. We run consistant 48-50mph (data logged) on two other stock UL1's and the two setups above pass them like they are standing still! Just have to make some lead adapters this winter for the EagleTree ( deans ultra to 5.5 bullet) and see if I can fry an Eagle Tree on a Nue1515
      So does the Feigo 7xl mount up directly to the stock motor mount without changing anything? Does it come with new mount bolts or do I use the old stock bolts currently installed? New guy quesitons i know
      - Diesel's Youtube
      - Diesel's Fleet
        • 9481
        #48
        Oh man!
        a 7XL in a UL-1, all I can say is yes it will mount up just fine
        make sure you bring someone with a video cam, cuz we all want to see this one run..
        • Diesel6401
          Memento Vivere
          • 4391
          #49
          Oh man!
          Thanks and does it come with new bolts or use the old ones? Their are a few other things I need to do to the ul and also gotta wait for weather to clear and it will be ready to go. I am currently hitting high 40s (46-47) close to 50 but can't get over the hump. I honestly think the boat will do over 50 with my setup, but I don't have the best gps (kinda big) and I think it is weighing me down due to the size of it. I am running 1" strut depth and a sharpened and balanced (by egneg) grim 40x57/3.
          - Diesel's Youtube
          - Diesel's Fleet
            • 9481
            #50
            the motor does not come with new bolts, you should be able to use the stock ones..
            what batteries are you using?
            are they at least 30c?
            • Diesel6401
              Memento Vivere
              • 4391
              #51
              I will be using 2 2s Zippy 4500mah 30c and 2 2s zippy 5000mah 30c heres the esc i ordered http://www.hobbycity.com/hobbycity/s...ter_Cooled_ESC
              - Diesel's Youtube
              - Diesel's Fleet
                • 9481
                #52
                have you used these batteries on the first go around with your UL-1?
                • Diesel6401
                  Memento Vivere
                  • 4391
                  #53
                  Yes i have, when I ordered the boat the 4500 30c where the first batteries I got with it which have several runs on them. The 5000 30c I just got and they only have 2 runs on them and work wonderfully temps where good on both sets of batteries. I just switched the stock esc to 5.5mm bullets.
                  On this new motor/esc combo I am going to use are the 5.5mm bullets i mentioned above over kill for the 3 wires for esc to motor connection or ok?
                  - Diesel's Youtube
                  - Diesel's Fleet
                    • 9481
                    #54
                    no such thing as over kill, trying to get more amps to our motors
                    I'm thinking of changing mine to 4mm on the motor
                    • Diesel6401
                      Memento Vivere
                      • 4391
                      #55
                      GREAT, every connection on the new setup will be 5.5 then. sweeeeeet, I can't wait to get this thing in action. After I get everything installed in the ul I am going to take the stock ul esc/motor and put it in my SV...
                      How do you feel about the esc I ordered? Do you think it will be up to the task?!?
                      - Diesel's Youtube
                      - Diesel's Fleet
                        • 9481
                        #56
                        That esc should do just fine, just watch your temps on the first run
                        • silvermansteve
                          • Aug 2009
                          • 152
                          #57
                          Grimracer did you delete the picture of the new cat? I can't find it.
                          • longballlumber
                            • 3417
                            #58
                            Here you go...
                            http://forums.offshoreelectrics.com/...ad.php?t=10827
                            • Colby
                              • Dec 2009
                              • 54
                              #59
                              Is there a direct link. The above link goes to another long thread which goes to another... etc.
                              Thanks
                              • longballlumber
                                • 3417
                                #60
                                Thanks
                                I guess I don't see the problem... They guy asked for the picture and that is what I gave him.... I can only assume you want this link instead?
                                http://forums.offshoreelectrics.com/...2&d=1255540288
