Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "scheme" in phar://.../vb/vb.phar/api/content/link.php on line 2 Warning: Undefined array key "host" in phar://.../vb/vb.phar/api/content/link.php on line 2 Motor upgrade - RcBoaters Forum
Motor upgrade
  • FEJohn
    • 25
    Motor upgrade
    Is anyone out there running an upgraded motor? If so, any feedback would be great.
    Aquacraft UL-1
    Aquacraft Rio 51 Gas (modified)
    Zipp Kits Easy Vee
    • 9481
    what are you looking for?
    • FEJohn
      • 25
      Something that puts out more power, I wanna keep the same esc tho if I can do that. Sorry it's a vage answer I just wanna know what my options are. Thanks!
      Aquacraft UL-1
      Zipp Kits Easy Vee
        • 9481
        More power?
        are you looking for more speed?
        these boats can do low 50s with the stock motor and esc
        • FEJohn
          • 25
          More speed, I want to safely run 2 3cell lipos without the motor or esc overheating. Do you know what a good set-up would be for this?
          Thanks for your help,
          John
          Aquacraft UL-1
          Zipp Kits Easy Vee
            • 9481
            Well first, how fast are you now?
            if your only in the 40s like most are, then work on the setup to get the boat to the 50s..
            What packs are your using? nimh or lipo and what size?
            alot of new boaters want more speed but yet can't get the stock setup maxed out yet..
            the stock esc and motor will take 5s with care..
            I'm looking to try 5s this summer, like someone on here has done with great results!
            I can get 52-53mph on my UL-1 running 4s, so 60mph on 5s should be doable
            If you want more than 60mph look towards another hydro as this one would be close to maxed out at low 60s
            • Diesel6401
              Memento Vivere
              • 4391
              What prop are you using to get into the 50s on stock power and 4s?
              - Diesel's Youtube
              - Diesel's Fleet
              • detox
                • 2357
                I used Grimracer's L40 x 57/3 prop and water conditions were smooth with slight wind ripple on top.
                • Diesel6401
                  Memento Vivere
                  • 4391
                  I will have to order that prop and get it sharpened & balanced. Right now I run a x440 and I like it, but my boat runs low 40s. Not sure if that is average speed for that prop on that boat or not. I'm still learning how to set up boats correctly.
                  - Diesel's Youtube
                  - Diesel's Fleet
                  • Diesel6401
                    Memento Vivere
                    • 4391
                    Another question I have and this is a true noob question, but please bare with me I have only been in this hobby for less than 4 months, but how and with what do you measure the strut depth and angle? Like I said please bare with me, but if I don't ask I'll never know.
                    - Diesel's Youtube
                    - Diesel's Fleet
                    • Grimracer
                      • 660
                      diesel,
                      I use a digital level and a solid rod protruding from the strut to measure the shaft angle.
                      To set the height I measure from the bottom transom of the boat to the work table below.
                      All measurements are taken with the boat resting on all three ride points.
                      Grim
                      • longballlumber
                        • 3417
                        This is the digital level that I have...
                        This is a must have for fine tuning ANY set up!
                        Later
                        Mike
                        • Diesel6401
                          Memento Vivere
                          • 4391
                          Thanx for the info Grim and Mike. You guys are great. Grim great boat I really love the ul-1 and I can't wait for the brushless cat you guys have in the works.
                          - Diesel's Youtube
                          - Diesel's Fleet
                            • 9481
                            me to!
                            • Grimracer
                              • 660
                              Thanks dudes.
                              I hope to be able to provide you with info on the boat soon but we still have a long way to go.
                              Lets see if I can find a pic for ya.. this is "Close" to the radio setup.. THIS IS AS GOOD AS IT GETS in FE RTRs...
                              Grim
                              EDIT
                              Im an idot.. thats a pic of the new cat.
