another mean machine set up
  • bustitup
    replied
    well I recieved my MM today.....first serious rc boat I have ever seen or handled before
    first I was amazed at how light and delicate it felt when I picked it up....I can see why they scream with the right power........ all the harware is instaled except for the motor mount, esc mount or a way to strap the batteries down
    also seems to have a second water pickup on the lower transom starboard side and one comming off the top of the rudder....should I use both?
    second question tonight
    when I mount the motor should it be mounted in a perfect strieght line with the flex shaft? some I have seen look like the kick the back of the motor up slightley...is this the norm or should it end up being a streight line with the angle of the flex as it comes up through the hull?
    Leave a comment:
  • Jeff Wohlt
    replied
    You will be fine starting with. You will be able to move up prop size without a problem but start with the 442. I could see a M545 doing a good job but, again, it depends on your set up and running habits. Tune the boat to run wide open and handle it without control issues. Should not run wet either. My MM runs great and runs on the last 2-3" of the hull. Same hardware as you have and set up exactly the same. My CG is at 8"-8.5" from rear of transom.
    I question the hi-model. Seems some have good luck and others don't. There are many offerings out there now without spending $400 for a ESC.
    Leave a comment:
  • bustitup
    replied
    Originally posted by Jeff Wohlt View Post
    Your choice is the best one...1650 x 6S. Easier on the ESC and can swing a bigger prop. Speeds will be in the 50's A good motor mount needs to have support for the rear of the motor as well. You can cut a wood wedge even but you need to make sure the motor does not bounce as it can then allow the cable to run on the stuffing tube edge.
    thanks for the quick responce...150 amp esc big enough?...or that himodel 200amp for $60?
    can you give me three props to start with I think its coming with a 442
    Leave a comment:
  • Jeff Wohlt
    replied
    Leave a comment:
  • bustitup
    started a topic another mean machine set up
    My mm should be here in a couple three days
    which of my motors would you use on what amount of cells and what three props should I start with?...also would 150 amp esc be enough
    I have
    1515/2.5d/s 1650kv
    1512/2.5d/s 2050kv
    and castle neu rated at 2200kv like a 1515/1y but its finned
    i'm leaning towards the 1650kv on 6s
    I also need a motor mount ...please look at the pics of what I have and what mount would you go with
    this is my first rigging
    pics of MM here
    http://forums.offshoreelectrics.com/...ead.php?t=6477
