What TP engine is this ?
  • Jlov
    • Nov 2013
    • 825
    I recently purchased this boat with this motor in it and I can?t find any info on it can anyone tell me what TP Power motor this is and what KV it is or any information on it. Thank you in advance Jeff
  • RaceMechaniX
    • 3024
    What is the can diameter and length? The KV you will have to find my testing.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
      • 4338
      As Tyler mentioned, measure the motor and cross reference it to models available on the TP Power website. No way to know kV without testing RPM on a known voltage, assuming the hand written kV rating sticker has been removed. Those don't last long.
      Can you not contact the previous owner?
      • zooma
        Local club FE racer
        • May 2014
        • 653
        If you can rotate the motor in the mount, you may find a label on the can near the back end bell. BTW, you might want to put zip ties on those cooling hoses.
        Ron - The Villages, FL
        • Jlov
          • Nov 2013
          • 825
          The motor is 4 1/2 in long and 7 1/4 in diameter. I was also thinking maybe the KV is on the motor underneath the cooling sleeve. I will zip tie all the hoses yes thanks
          • Panchothedog
            • Oct 2015
            • 173
            You might want to consider measuring again or checking out your measuring instrument. I seriously doubt that the motor is 7 1/4" in diameter. That would be the size of a gallon paint can.
            • TRUCKPULL
              • 3293
              TP 100 XL
              Larry
              • Jlov
                • Nov 2013
                • 825
                I measured around the outside diameter. I guess the measurement required was 2 1/8 in diameter x 4 1/2 in long
                • Jlov
                  • Nov 2013
                  • 825
                  I took Zoomas advice and rotated the motor and hand written tag was still there. Thanks everyone
                  • Jlov
                    • Nov 2013
                    • 825
                    I think this is the motor the specs on the diameter and the length match up as well as the KV
                    • Jlov
                      • Nov 2013
                      • 825
                      Also when I got this boat the ESC was burned up. I ordered this one,will this be ample enough for this boat? Octura x648 prop. Im running 5S and 6S batteries in series
                      • TRUCKPULL
                        • 3293
                        A little on the small side.
                        The motor is {Continuous Power (W): 7200}
                        On 6S this would be 300A
                        What size boat is this beast in?
                        Larry
                        • Jlov
                          • Nov 2013
                          • 825
                          3C3AF17C-2B19-41C8-A0CC-0BACA519C94E.jpgIt?s a 48? cat. Hydro and Marine Oliver Siess
                          • Jlov
                            • Nov 2013
                            • 825
                            Back to Amazon goes that 180amp ESC. Now on the hunt for a 300 amp like you suggested. There’s one in offshores store for $300. Will that one be ok ?
                            • HTVboats
                              • 936
                              If your not going over 8S the Castle will take over 300 amps, Stump Fab has water cooling plates so surf the site a bit. On 8S 970kv would be a no load 28700 rpm and probably 21000-23000 actual. 67-72mm (gas props) might work as you have the power
                              Mic
                              Mic Halbrehder
                              IMPBA 8656
                              NAMBA 1414
