I am defeated and I give up
  • H&MWill
    • 680
    As many of you know i have been trying to get a Toysport Triton to handle for a while now. Well I quit I just cant get this boat setup. It handles like S***. I am going to list the hull on the swap shop soon. I will be keeping the 8 XL, Hydra 240 Speedmaster hdwe. I want to purchase a Delta Force hull. Which one should I get and what prop on direct drive with 4S lipos? Thanks Will
    Many issues!!!
  • H&MWill
    • 680
    Alright, thanks to Doug Smock Im gonna try some more stuff first. Doug I truly appreciate all the great info you provided me. Thanks Will
    Many issues!!!
    • Doug Smock
      • 5359
      Yeah you're not done yet.
      Ask brother Tom to post a pic of what a boat looks like when you're absolutly DONE with it.
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • Jeepers
        • May 2007
        • 2050
        I laughed my @$$ off when Tom did that!
        • H&MWill
          • 680
          Alright I gotta know. Can ya post a pic Tom?
          Many issues!!!
          • wickedgmc
            • 823
            I looked, it is not here anymore. Looks like he cleaned his photobucket account
            • Steven Vaccaro
              Administrator
              • 8932
              What handling problems are you seeing? That hull should handle well into the high to low 50's mph area.
              Steven Vaccaro
              • SJFE
                • 4867
                Doug I will post that picture for will this evening. I don't have it hosted on the bucket any more & am @ work. Will I don't reccomend this method of stress relief but I have to tell you it WORKS. Stay tuned
                • Doug Smock
                  • 5359
                  Thanks Tom, it may help the guy out. That was by far the funniest thing I have ever seen, read on a FE forum.
                  Doug
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • SJFE
                    • 4867
                    Well I am glad I was able to inhance your forum experince. . Ya know...I can't rule out that it will never happen again.
                    • H&MWill
                      • 680
                      Just wont stop prop walking on me. Hooks real bad to the right and spins out when wide open.
                      Many issues!!!
                      • Ctonez
                        • Jul 2007
                        • 410
                        mine (similar setup) seems very sensitive to center of gravity changes. I tried moving the batteries to get the CG to around 27% and it was awful.
                        At 30% it's a tad wet, (likely underpropped) but handles really well for me.
                        I have a pretty huge turn fin...dunno how much of a factor it really is though.
                        My rudder is probably extending 2" below the strut.
                        Speedmaster strut is shortened, can't remember how long it is...I'm sure pics would help, I'll work on that.
                          Stepped hulls can be difficult to tune, and what works on a no-step may not apply to your stepped Triton. With my stepped hull experience (self-designs and an H&M Streamer), the strut needs to be parallel with the points of the steps - which I believe you tried. The CG is critical, and depends on the size and placement of the steps. But the problems mentioned above suggest a rudder which is too short. Spinning out is a common side effect of a short rudder, since it is the only thing that is holding the transom in place against prop walk. The effect is magnified with a stepped hull since there is less keel near the transom to help hold against prop walk.
                          It is difficult to tell from your photos in the Triton thread, but you should have a minimum of 2" of rudder below the bottom of the strut. It may take more than that. Remember that when at full speed on step the top of the rudder is out of the water, further reducing the side resistance to prop walk. A longer and perhaps wider rudder may solve the problems.
                          • H&MWill
                            • 680
                            Sounds good guys. Thanks Ill try out some more stuff this weekend. Will
                            Many issues!!!
                            • SJFE
                              • 4867
                              See Will this is what happens when Mr. SJFE has HAD ENOUGH. We get what we have here ..... Like I said before it does help with stress but the with progress on a build.
                              Yes it was stopmed...
