Genesis question
    Hey Jerry,
    I love the paint job.
    I would take off the washer at the drive dog and strut,
    And just keep a gap of ID of shaft.
    That may be your problem their.
    I just use a gap on all my boats drive lines.
    • HYDROJERRY
      • Jan 2010
      • 2709
      #77
      Yeah thats the coupler,,, (parts) what parts are you waiting on??
      • HYDROJERRY
        • Jan 2010
        • 2709
        #78
        thanks Lenny and its funny you say that cuz after every run the shaft was drawn up to the ring when i installed it with a gap.
        • Prop-a-Gator
          • Feb 2012
          • 168
          #79
          Yeah, that's what happens when the coupler starts slipping. Come to think of it, the reason I know that is because the coupler DID slip at one time. So much for my prior statement! It's been a while and my memory sucks. Your statement about the dissappearing gap triggered something in the cobwebs. It had me baffled for a while because it never completely let go like yours. I thought I had the incredible shrinking flex cable!! I just cranked on it, but like I said earlier - stick with what you know works.
          I'm waiting on a new ESC from FC...
          Disclaimer: I hereby accept the potential loss of motor, ESC, entire boat, or credit rating, and forfeit all expectations of success.
            Hi,
            Esc, Need to get something to for my 48"stealth some day.
            What setup do you have in your boat and on what prop ?
            • 1945dave
              • Mar 2012
              • 295
              #81
              Jerry, Was this the Octura collet coupler? What is the other brand couple?
              Dave
              • 1945dave
                • Mar 2012
                • 295
                #82
                Jerry, another small bit of advice. While your photos are not of the final setup try to remember you want the water line going to the motor mount inlet to exit the cooling jacket from the highest point possible. Not the closest low exit point. Make sense?
                Dave
                • BHChieftain
                  Fast Electric Addict
                  • 2051
                  #83
                  I saw someone in this thread mention MR200 receiver. I saw this post below showing an interaction problem with MR200 and a Hitech servo--
                  Hydrojerry-- what is your config?
                  http://forums.offshoreelectrics.com/...MR-200-problem
                  Chief
                  • HYDROJERRY
                    • Jan 2010
                    • 2709
                    #84
                    Ok Dave ill have to look at it tonight,, was trying to get it back together in a hurry must have missed that,,and the coupler is a fightercat coupler, i no i got it for the wright size and have broken more than one octura couplers tightening them so i no i had this FCone very tight,,, thinking its drawing the flex up when running and pulling it up into the coupler more than it should so now im thinking either ill put my old one back on or just cut a small peice of tube to go in it so it cant draw the flex up inside it anyfarther than i set it..
                    • HYDROJERRY
                      • Jan 2010
                      • 2709
                      #85
                      not using that one Cheiff, im using a tactic, leopard 4074 2200, SF2ooa esc, m445 prop on two 5s 5ooo.
                      • Prop-a-Gator
                        • Feb 2012
                        • 168
                        #86
                        Hi,
                        Lenny, not much in my boat right now! Last setup was FC3740 1760 running up to 6S1P 5000mAh, FC 16S300A ESC, and a m445 s/b by me. I either run in a big-choppy lake or a long, narrow pond. Last time was in the narrow pond and the boat was still veering right so I could only get one sustained WOT pass. Unfortunately, it was also the last pass for the ESC. The gps read 64.5 mph max (reset just prior to taping hatch), but when I downloaded KML to google earth, it showed 51 mph max. Not sure which to believe. I need to resin some FG over the internal hull burn damage. I've been too lazy to put it all back together.
                        In those few runs, the boat was really ripping with the m445. Prather S215 also seemed to run well on 6S, but of course it's relatively small in dia and there was some cavitation at first - which doesn't bother me since I don't race.
                        • HYDROJERRY
                          • Jan 2010
                          • 2709
                          #87
                          Come on Gator youll be kicking your self when you get that new esc but havent finished the boat!!!
                          • Prop-a-Gator
                            • Feb 2012
                            • 168
                            #88
                            I know that is exactly what will happen! I've gotten distracted by rc planes recently but that may be on hold as well. Back to boats? lol
                            • HYDROJERRY
                              • Jan 2010
                              • 2709
                              #89
                              Hay can you guys post some pics of your offset rudder deal,,, i made mine offset but realy dont like it and was going to maybe put it back normal just with a stronger pushrod..
                              • Rocstar
                                Joel Mertz
                                • 1536
                                #90
                                Here is the one I am using from FC with a 2mm Stainless push rod with ball pivot,
