tlandauer.
Are you saying that you have the free floating Speedmaster bushing in the strut. Like this.
http://www.offshoreelectrics.com/pro...=ros-spdsd-187
It should be free spinning in a brass sleeve that is fixed in the strut. The bushing should be easy to remove as it is free floating.
If not. there should be two lead teflon bushes in there. One at the very end & one an inch or so in front of it. Like these.
http://www.offshoreelectrics.com/pro...od=oct-oc6ltsb
Perhaps the front bearing is already flogged out? I've seen that before too when the front of the stub shaft didn't reach it & the .150 flex was whipping around loose in the bushing.
But, if neither of the above scenarios fit your setup , maybe they have produced a stinger with just one long brass sleeve for the stub shaft to run in. But I haven't seen one myself if that's the case.
Use a piece of fine wire to "feel" for the length of the rear bush & "feel for the shoulder of the front bush. Mark the positions on the outside of the stinger and see how the stubshaft & flex line up with them
That is, if you don't have the Speedmaster floating bush setup.
Sorry if this is a bit long winded, but I'd really like to get to the bottom of this. There's a solution somewhere.
Cheers.
Paul.
Surprised that you said there are TWO bushings, I thought it is just a long brass bushing inserted into the stinger?
Cheers.
Paul.
