Thanks Steven................ Others were asking you about top end on the thread, i got 46 mph as a high reading with the same setup and an x442..............just fyi
32 pursuit
NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
pursuit
Originally posted by uliusmc View PostSavy where did you get the battery and how much, also where did you get prop. I was looking at the kingtech and it says it brings prop and diffrent motor than the one from ose.
and i got my prop from here.
Hey savy what do you mean in parellel ,is this 1 or 2 packs. I and went to the site u send me great prices .w hat mah are u using. How much does the prop cost.Originally posted by the savy fluxer View Posthttp://www.hobbypartz.com/skylipo5s40c.html
parellel means 2 packs with the positives hooked togeth to make one battery lead and the negative done the same as well. it gives the same voltage as one battery but has 2 times the capacity.
series means, one positive and one negitive from each battery made into one battery lead and again the other postive and negitive made into another. this gives you the same capacity as one battery, but doubles your voltage.
++ & -- = parellel
+- & +- = series
does this make sence?
i use 40 c lipo's so in parellel in makes 80c.
this is the prop i use : http://www.offshoreelectrics.com/pro...?prod=oct-x642
but if you want a sharpend and balanced prop: http://www.offshoreelectrics.com/pro...rod=octsb-x642
i also have the one pcs driveshaft, much easier to service.
Hey savy thank you for all your help did u get the pursuit from ose or kintech the motors are diffrent.Originally posted by the savy fluxer View Postparellel means 2 packs with the positives hooked togeth to make one battery lead and the negative done the same as well. it gives the same voltage as one battery but has 2 times the capacity.
++ & -- = parellel
+- & +- = series
Still 40c no matter how many you hook together.............Originally posted by the savy fluxer View Postparellel means 2 packs with the positives hooked togeth to make one battery lead and the negative done the same as well. it gives the same voltage as one battery but has 2 times the capacity.
++ & -- = parellel
+- & +- = series
40c x 5000mah = 200 cont. amps
40c x (2 x 5000) = 400 cont. amps
Good explaination of the series/parallel though..............
we don't build them. Just do some tweaking. Shippings about 15 to 20 to most places in the USAOriginally posted by uliusmc View PostSteven do you build these boats that your are selling and also how much for shipping to miami fl. Thank youSteven Vaccaro
i've ordered a couple of small things from here, and in my years of lurking in this and other forums, i have never heard anybody, ever, say they had buyer's remorse dealing with osc. to the contrary, everybody seems happy. i have never read anything negative at all from anyone.
