32 pursuit
  • Make-a-Wake
    FE Rules!
    • 6057
    Thanks Steven................ Others were asking you about top end on the thread, i got 46 mph as a high reading with the same setup and an x442..............just fyi
    • the savy fluxer
      • 83
      pursuit top speed
      i hitting 64 mph with 5s in parellel 40c with a octura x642
      • uliusmc
        • Aug 2011
        • 9
        Savy where did you get the battery and how much, also where did you get prop. I was looking at the kingtech and it says it brings prop and diffrent motor than the one from ose.
        • uliusmc
          • Aug 2011
          • 9
          It's a forum only item at this pointhttp://forums.offshoreelectrics.com/showthread.php?27325-Pursuit-Mono-kits.
          Steven do you build these boats that your are selling and also how much for shipping to miami fl. Thank you
          • the savy fluxer
            • 83
            pursuit
            and i got my prop from here.
            • uliusmc
              • Aug 2011
              • 9
              http://www.hobbypartz.com/skylipo5s40c.html
              Hey savy what do you mean in parellel ,is this 1 or 2 packs. I and went to the site u send me great prices .w hat mah are u using. How much does the prop cost.
              • the savy fluxer
                • 83
                parellel means 2 packs with the positives hooked togeth to make one battery lead and the negative done the same as well. it gives the same voltage as one battery but has 2 times the capacity.
                series means, one positive and one negitive from each battery made into one battery lead and again the other postive and negitive made into another. this gives you the same capacity as one battery, but doubles your voltage.
                ++ & -- = parellel
                +- & +- = series
                does this make sence?
                i use 40 c lipo's so in parellel in makes 80c.
                this is the prop i use : http://www.offshoreelectrics.com/pro...?prod=oct-x642
                but if you want a sharpend and balanced prop: http://www.offshoreelectrics.com/pro...rod=octsb-x642
                i also have the one pcs driveshaft, much easier to service.
                • uliusmc
                  • Aug 2011
                  • 9
                  ++ & -- = parellel
                  +- & +- = series
                  Hey savy thank you for all your help did u get the pursuit from ose or kintech the motors are diffrent.
                  • Make-a-Wake
                    FE Rules!
                    • 6057
                    ++ & -- = parellel
                    +- & +- = series
                    Still 40c no matter how many you hook together.............
                    40c x 5000mah = 200 cont. amps
                    40c x (2 x 5000) = 400 cont. amps
                    Good explaination of the series/parallel though..............
                    • the savy fluxer
                      • 83
                      i stand corrected
                      • Steven Vaccaro
                        Administrator
                        • 8932
                        we don't build them. Just do some tweaking. Shippings about 15 to 20 to most places in the USA
                        Steven Vaccaro
                        • silvermansteve
                          • Aug 2009
                          • 152
                          i've ordered a couple of small things from here, and in my years of lurking in this and other forums, i have never heard anybody, ever, say they had buyer's remorse dealing with osc. to the contrary, everybody seems happy. i have never read anything negative at all from anyone.
