32 pursuit
  • uliusmc
    • Aug 2011
    • 9
    32 pursuit
    I want to start of by saying hello to everyone and also to say this is a great site. I am new to FE boats, but. have been into rc electric and nitro cars since the mid 80's. I want to get into these boats, and was looking at the 32 pursuit from kingtech for 425 or the one from ose for 400. Are they diffrent or the same, notive diffrent esc on the one from ose. I am sorry. I have so many questions. What are the run times on these boats. Thank you for a great site and to all for all the information being shared here.
  • Steven Vaccaro
    Administrator
    • 8932
    Runtime depends on the batteries used. A 35c 5000mah 4s pack will work with about 4 plus minutes runtime at full speed.
    Steven Vaccaro
    • uliusmc
      • Aug 2011
      • 9
      Thank you for responding steven, what do you think about the pursuit boat from hobby king.
      • Drax21
        • Jul 2011
        • 1077
        HK Pursuit is ok, I have one, I find it to be a strong hull, but you would have to replace the stock motor and buy an esc separately, also HK sells it with a 2 piece flex cable which wears too easy. Steve has the 1 piece to go in this which is a lot better. If I was looking to buy one again, I'd definitely buy from here.
        • Steven Vaccaro
          Administrator
          • 8932
          As Drax said, the HK boat comes with a substandard motor and esc. The OSE version has a motor and esc that will make the boat perform.
          Steven Vaccaro
          • uliusmc
            • Aug 2011
            • 9
            Ok guys remember I am new to this,but from what I have read in 3 days all boats have to have there electrics replaced. Is this the case with the pursuit from ose. And what speeds are u getting with the stock boat from ose. Thank you
            • znus
              Broke, as usual
              • Jun 2011
              • 120
              Dunno stock? Maybe in the high 30's low 40's? The OSE will probably get you in the 50's and that's plenty plenty plenty fast. Almost too fast for comfort if you´re not used to it. You really cannot play around with a boat doing 40+ but speed is what it's all about :-)
              25" Arrowana with Etti 2970 3300kV. RCMK Flying Cat with twin HOR Outboards. 2 x SSS 4092 2140kV. Faluga 45" with Leo 56110 620 kv on 12s.
              • uliusmc
                • Aug 2011
                • 9
                So the boat from ose will hit 50 mph with the stock esc and motor. What prop are you using and what battery,also steven how much would it cost to ship to miami FL.
                Thanks again for taking your time to explain to me.
                • Basstronics
                  • 2384
                  Speaking as a newbie still I can tell you 40 MPH is faster than hell to the new boater, such as yourself.
                  Not all rtr boats need the electrics replaced. This boat from OSE just needs the parts to finish it and water. Im not sure if Steven sets them up or does any "inspection" type work. Many of the RTR's need to be inspected and fixed as necessary. Steve would have to answer if this things ready to rock right out of the box or not.
                  • Drax21
                    • Jul 2011
                    • 1077
                    You will not need to change the motor or esc in the OSE version as these are great. The motor in the HK version has to be changed for good performance. I have seen the set up from OSE do 43mph on 4s
                    • the savy fluxer
                      • 83
                      i have the one from hobbyking and i had to completley gut it. i wish i would have bought the one from here. it would have been the same price in the long run and a whole lot less time building and more time ripping up the water.
                      • Make-a-Wake
                        FE Rules!
                        • 6057
                        I feel like a complete moron since i cannot find the OSE Pursuit for $400..........link anyone.............??????????
                        • the savy fluxer
                          • 83
                          Look up delta force 32" its the same thing
                          • Make-a-Wake
                            FE Rules!
                            • 6057
                            Dont see a DF32 ARTR for $400 either.............
                            • Steven Vaccaro
                              Administrator
                              • 8932
                              It's a forum only item at this pointhttp://forums.offshoreelectrics.com/showthread.php?27325-Pursuit-Mono-kits.
                              Steven Vaccaro
