HK Vanquish
  • Brushless01
    • Apr 2010
    • 489
    #136
    For me it says its $179.99 !
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
    • FighterCat57
      "The" Fighter Cat
      • Apr 2010
      • 3784
      #137
      This happened with the "mini-cat" and the apparition for a while too...
      • Diesel6401
        Memento Vivere
        • 4391
        #138
        Originally posted by 6sHyper View Post
        My motor did not show up, someone was a little slow getting to the post office.......................... I did throw my cc1520 in her just for kicks though!! ran it on 6s1p with an x448 prop, it went for a couple passes and was definately running what appeared to be nose heavy, although all my weight is rear of center and my batts were beside the motor. It was all that bad though, it almost got on plain, but just not there. I'm confident the extra power form teh 1717 and 6s2p and my extra 2 batts are going in the very rear, should get this thing on plain!!!
        I was just gonna grab the camera but on the 3rd pass the flexshaft broke 1 1/2" from the motor collet, haha stupid chinese 2 piece shafts! I ordered a .187 flex with 3/16" prop shaft.
        That's exactly how mine ran, plowed through the water the whole time. When I got on the throttle with the 1717 the boat actually submarined and NEVER fully got on plane outta the water. I kept dialing the trim tabs up and seemed to make some progress until I lost my flex (first time that ever happened) and had to call it a day. Try taking the trim tabs off, that was going to be my next move.
        - Diesel's Youtube
        - Diesel's Fleet
        • FighterCat57
          "The" Fighter Cat
          • Apr 2010
          • 3784
          #139
          The bottom of the hull feels "sticky" think there might be some benefit to scuffing it?
          • Diesel6401
            Memento Vivere
            • 4391
            #140
            Scuffing is normally good. The way mine was plowing through the water though scuffing wouldn't make a difference, mine was def a trim issue. The bow was just being forced down. I think removing the trim tabs will def help. How much I am not sure. Let me know when you get those mounts. I may be in the line for one with a Osprey
            - Diesel's Youtube
            - Diesel's Fleet
            • FighterCat57
              "The" Fighter Cat
              • Apr 2010
              • 3784
              #141
              Hopefully next week I'll have the prototypes (half dozen of them) and start the Osprey build. Hmmm. Makes me wonder if I started a build thread on it... I think I did last year... Let me dig that up and update it.
              I'm following this Vanquish thread closely as I have one here on the shelf that I want to setup as a sport boat 35-40ish and run it in the atlantic ocean here at the inlet. Basically shooting for max run time as I'll have to walk it to the beach.
              • carlcisneros
                • Jan 2010
                • 1237
                #142
                one thing to check out on the BOTTOM of the hull is a HOOK in it.
                Lay a straight edge down on it and check to see if there is a hook in th ebottom towards the back of the boat.
                If there is, then remove the trim tabs, RAISE the stinger up about 1/8" and set the stringer angle to about 1-1.5 degrees POSITIVE. (prop pointing up instead of down.)
                It kind of sounds like they copied one hul for the deck and another hull for the bottom.
                meaning, Delta Force for the deck and maybe Seaducer for the bottom.
                Can't hurt ya know to try it.
                  • 9481
                  #143
                  Good call
                  • FighterCat57
                    "The" Fighter Cat
                    • Apr 2010
                    • 3784
                    #144
                    See if any of these help
                    • FighterCat57
                      "The" Fighter Cat
                      • Apr 2010
                      • 3784
                      #145
                      or these..
                      • martin
                        • 2881
                        #146
                        Thats not just hook, Its hook line & sinker. Hull needs some straight stiffeners bonded inside to take most of the hook out & then filled. Now these Vanquish hulls have risen $100 to $179 their not worth the money. Martin.
                        • FighterCat57
                          "The" Fighter Cat
                          • Apr 2010
                          • 3784
                          #147
                          I was wondering how these hulls are possibly straight without any rails. Even in the 33" hulls, it's hard to strengthen them enough to be straight without rails. There's just so much flat real estate and nothing to support it.
                          • carlcisneros
                            • Jan 2010
                            • 1237
                            #148
                            yepper, there it is folks.
                            now you know why the hulls are not breaking free and riding the way they should be.
                            Ben, Slot your stinger mounting holes and raise it the 1/8" like i suggested, remove of REALLY RAISE the trim tabs up so they are not really being worth anything, then chuck it out on the water and see what happens FIRST.
                            The bottom of it looks alot like a Seaducer. but it looks like it is more hooked onone side then the other!!!!!!! (might be just the camera angle also.)
                            • FighterCat57
                              "The" Fighter Cat
                              • Apr 2010
                              • 3784
                              #149
                              Yeah, it's a little lop sided, some is camera angles, but mostly the bottom of this hull is umm.... a wee bit warped.
                              The good news it is flexible, so with some support and some fiberglass it can be straightened... but wow. Ouch.
                              • martin
                                • 2881
                                #150
                                Unless you make your mould from a plug that is straight its always a problem when they make their moulds as knock offs simply using a finnished thin hull as the master for the mould. I have checked one off the Osprey hulls which i believe is also a copy & its no where near as bad as that Vanquish hull, Theirs a bit of hook in the last 3-4" but only around 1.5mm at its deepest point. Martin.
