Got my Pursuit Mono! - Some Questions
  • FighterCat57
    "The" Fighter Cat
    • Apr 2010
    • 3784
    Originally posted by Diesel6401 View Post
    Is that a Leopard motor? If so you will def want to dump that 4mm shaft, that leopard will destroy that 4mm system. You will want a .150 at least or bump up to the .187 like I did. Very nice by the way. I run 2 4s 3600mah 30c in parallel in my pursuit. I still need to get some video on that bad boy.
    Diesel.... 4mm is bigger than .150.
    Surprisingly the 4mm cables do hold up well. I ran one with a CC 1512 2650kv at 40k rpm for a while.
    These are cool little boats.
    BTW- I know these strut/rudder systems intimately, they are made by TFL hobbies let me know if you need any assistance and/or replacement parts. I know Kintec carries them as well.
    PS- I'm working on carrying 4mm .062 wire drive shafts to replace the two piece cables. Having them made now should be available in December.
    Enjoy!
    • domp444
      • Jul 2009
      • 901
      Hey Fighter!
      I also saw the new Cat that you have coming! That looks pretty awesome, and I might get it :)
      I used the one pc flex shaft today, and well, it didn't go too well. Check out my other thread I just posted.
      • club17
        • Jan 2011
        • 16
        How to you remove the transfers from this boat(pursuit and LIPO). Have you got a link to the replacement wire shafts (4mm .062 cable).
