Good looking boat!! Looking forward to see some vids of it running..
Got my Pursuit Mono! - Some Questions
I'll take a video when I run it! For now, here's some more pics...
I put epoxy over all the wood and added some to the motor mount. Everything seems a lot more sturdy now. Also installed the servo, turn fins, and secured the rudder in place.
Oh and I figured out how to get the shaft out! Haha, wasn't too hard. Also, Jan said that the Pursuit now comes with a 3/16 flex shaft to handle the extra power. I ordered the one piece flex shaft but I think I'll use this one for now.
At first I was gonna use an extra rx for the boat and use the 2.4ghz tx I have for my SV27. But after some thinking, I decided to go with another 2.4ghz tx/rx. There's a lot of advantages to having a separate tx for each boat IMO.
Oh and Diesel (or whoever else has a Pursuit), where do the strut seals go?SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
Oh yeah! Jan from Kintec sent me a new one and I sent the clogged one back. Hopefully I'll get it in time for a weekend run :)SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
Yep, he's a great guy and it's always a pleasure to deal with him!
And that's probably what I would say if I tried painting mine, ahaha. I'm sure it'll look good though. Pics when you're finished!SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
Alright, I think I figured out where the strut seals go. I put 2 of them inside the strut where the shaft goes.
But, it didn't stop the leaking from the teflon liner. I put 'er in the tub and there is water coming in from the teflon liner. I thought, maybe it needs some grease. So I put grease on the shaft, and water is still dripping in. I don't know what else to do
Never mind - got everything sorted out. I put the strut seals on wrong at first which is why it was leaking. No water now, hopefully no water when I run it!SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
From what I understand - the strut seals go on the teflon liner and then you have to push the strut back on. You have to find a way to hold the seals in place so that when you put the strut back on it doesn't push them back. I just held the top with a small allen key and the bottom with my finger.
You should get the Pursuit, it's an awesome boat. I would recommend getting the one pc 3/16 flex shaft with it, since you'd have to put the strut seals back on every time you want to grease it. Also, it's just a lot easier to work with.SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
Pursuit
Yes I have one boat with the 2 piece shaft that I need to convert, it is a pain for routine greasing.
Thanks for the hint on seals
Originally posted by domp444 View PostFrom what I understand - the strut seals go on the teflon liner and then you have to push the strut back on. You have to find a way to hold the seals in place so that when you put the strut back on it doesn't push them back. I just held the top with a small allen key and the bottom with my finger.
The 2 pc shaft is pretty good in terms of reliability, but it's just really inconvenient. My props fit a lot better on the 1 pc than the 2 pc. Some of them were too long and so the bullet set screw wouldn't screw into the slot, with the 1 pc they go on fine since it only requires screwing on the nut and bullet (if you get one).SV27 w/ Ammo 2300 / Stock ESC || Pursuit w/ Leopard 4074 2200kv / SeaKing 120a ESC || MHZ Drambuie on Ice w/ 2x Schulze 4.160wk's / 2x Neu 2215 1.5y's
