Turnigy vs. Hyperion Eagle Tree Comparison
  • scoota
    FE DOWN UNDER
    • Dec 2008
    • 439
    #31
    I have various 6S5000+
    packs always cycled gently first 3-5 runs
    run to 80% or 3.3v min
    My G3 6S35C5500 are still 95% ok after 125+ cycles... 16 months..just longer to balance
    TP 6S45C5000 huffed and puffed after 10 cycles .. 2 weeks... expensive choice !
    Same setups and run characteristics..
    And Andrew at Fast Electrics.com swears by Thunder powers glad i didnt waste my $$$ on them !!!!
    UL1- 1515 castle/neu / 240 swordfish
    SV27- with UL1 running gear
    33 Delta Force - 1521-1.5D/Neu/ 240 swordfish/4S2P
    • properchopper
      rcgoatbuild@snotmail.com
      • 7708
      #32
      The log shows pack voltage Vs accumulative current draw... mAh
      why not PackVoltage Vs Watts ?
      Assuming this is a mimic wot run, the data would show available power output from each pack
      Ive Chinese 'no-names' that outperform TP45 on Vdrop... but on available Amps the TP output more power.(watts)...
      volts/watts I think a better judge of battery .
      regs
      W
      Pack volts [purple] vs. Watts [yellow-orange]
      As I see it, the critical variable is pack volts, given that prop speed [ and forward velocity] is a function of KV multiplied by Voltage. { That is, if maximum speed is the designated criterion}. For heat racing applications, the average voltage level is the important factor; high starting voltage that sags drastically during the race won't be desirable. In these sessions it won't be easy to examine the average voltage/session since the sessions consist of : plug-in/tape up/run/untape/unplug. Extracting the pure run figures would be difficult. What's interesting is that the Turnigy has a more gradual voltage decay compared to the Hyperion. In this example, in a race, the Hyperion would get you out front first but you'd get slower towards the end of the race as the Turnigy boat would start to catch up ! [ of course, in racing, highest top speed is only one of many components in winning]
      • BakedMopar
        No Mo Slipah
        • Sep 2009
        • 1743
        #33
        So far I have only been running HK LiPos. Almost every pack I have starts to drop in performance after two dozen cycles. At around 50 cycles they start to come in a little puffy. They range from 20-30c to 40-50c. Run down to 80% and charged at 1c.
        • properchopper
          • 7708
          #34
          My experience exactly !
          • drwayne
            • 3012
            #35
            Assuming you ran both packs to LVC.. the turnigy gave lower watt/hrs than the Hyperion.. similar W outputs as shown by the graph.. but the turnigy 90 secs Vs the hyperion 125 is a large gain in performance.
            Accumulative draw ( total drawn ) from the T pack was substantially less than the Hyp, running both down to LVC.
            The Turnigy with a 90 sec runtime window may not finish the race compared the hyperion's 125 !
            On the face of the data displayed, id run the T pack for a sprint, and the Hyp for an oval.
            W
            Scoota:
            AndrewG sells to a wide market.,,
            some demand that extra 0.5A edge to win races.
            others consider the added $$$ unjustifiable for sport.
            Never met, but spoken on phone at various.
            I considered the TP brilliant, until they went pop fizzle a few months early.
            with lvc3.3 I have no explanation, when G3 ran same setup ok
            • properchopper
              • 7708
              #36
              HK just shipped my 45-90 C nanos. Have high hopes (and a vastly depleting wallet)
              • 6S HYDRO
                • 1325
                #37
                I think you should have at least used the 40-50c turnigy's Tony- those 30-40 ones are crap, and your putting them up against 35-70c packs
                • properchopper
                  • 7708
                  #38
                  Paul, I only had the 30-40 C battery(s) to test ; I will test the nano 45-90 C packs soon.
                  • 6S HYDRO
                    • 1325
                    #39
                    cool Tony, by the way your new cyberstorm is sick. to bad for old green eyes
                    • properchopper
                      • 7708
                      #40
                      Paul, If you look real hard, there may still be some of old green eye's DNA left on your dining room table
                      • 6S HYDRO
                        • 1325
                        #41
                        nope i scraped it off and have been preserving it in a jar< gonna do some crazy fe vodoo hexes
                        • properchopper
                          • 7708
                          #42
                          • sailr
                            • 7128
                            #43
                            I'm puzzled why the Australian dealer doesn't have 45C packs? They have been out here for quite some time.
                            Originally posted by scoota View Post
                            Ok will do , just checked Hyperion Australia web site , still no 2s 45c 5000 packs in stock & he has not put any prices on his web site yet ,so i cant compare your prices with his anyway ...
                            Mini Cat Racing USA
                            www.minicatracingusa.com
                            • properchopper
                              • 7708
                              #44
                              Got the nano packs today ; will do an Eagletree comparison in a day or so using the same setup previously used.
                              Kinda wierd that the HK web specs indicate :
                              585 g
                              L : 166 mm
                              W: 37 mm
                              H : 50 mm
                              5.5 bullets
                              8 AWG pictured
                              Actual :
                              571 g
                              L : 150 mm
                              W : 33 mm
                              H : 47 mm
                              4.5 connector
                              10 AWG
                              Same decal, 'tho !
                              • v-spec
                                • Jun 2009
                                • 1046
                                #45
                                Hope they work good so I can buy some for sport packs
