Any testing on those nano's yet Tony?
Turnigy vs. Hyperion Eagle Tree Comparison
Today's the day.Originally posted by alvinsmith75 View PostAny testing on those nano's yet Tony?
Here you go :
Left : Turnigy 4S 35C 5000 (with 25+ runs)
Middle : Hyperion G3 4S 35C with (20+ runs) $ 169.95 retail
Right : Turnigy Nano 4S 45C/90C (first run) $ 75.99 retail ( + shipping)
Not realy apples to apples because the nanos were brand new & the other two were used. Draw your own conclusions ; right NOW the nanos maintained a higher overall voltage, which indicates a higher prop speed I would think, thus higher top speed. Discuss as you wish !
Tony
Attached Files2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Yup; when the test was done, using the same M445 for testing all three, I put on my "special" race prop & she really ran fantastically !! I think the nanos are a good hit but time will tell.Originally posted by alvinsmith75 View PostInteresting.........................Now go put 25+ runs on that Nano
I just bought 2 of the new 45c Hyperions to try, but I don't have an eagle tree or any other test methods other than run the snot out of them.
I was using the turnigy 30c 5000mah and they didn't hold up well.
I'll GPS tomorrow.Originally posted by detox View PostDid your boat appear faster using the Nanos. Eagle Tree gps would be helpful.
...2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Here's the answer :Originally posted by detox View PostDid your boat appear faster using the Nanos. Eagle Tree gps would be helpful.
[ The original run at 53.6 mph was done with a fresh set of Hyperion 2S G3's in series]
I have to say that this is THE hot setup for max thrills and spec racing at a moderate price. My FE 30 has ONLY UL-1 internals; speed control, motor, servo, servo mount, drive cable, Tx & Rx. The boat handles so well at this speed [WFO in the turns] that it's a pleasure to drive, and nothing ever needed fiddling with once it came off the setup board.Attached Files2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Paul, You & the AZ guys should NOT get this boat ; this way I'll have some kind of chance next spring in spec LSH at WW VII.Originally posted by 6S HYDRO View PostHey tony ur just usin 4s1p right
