New Hobby King Cat (Surge Crusher)
  • ket2175
    replied
    Look like some of the people use heli or plane brushless motor for boat, is this ok?
    And is there any website, thats tell newbie like me , what is the motor speed for which size motor and suitable esc to match with.
    Many thanks
    Ket2175
    Leave a comment:
  • maxmekker
    replied
    nope. Only the 180 amp , and I got one of this for spare, but sold it before I tried it.
    HK-B125A (Enter in search bar)
    I did however, remove the heat sink, sanded it down smooth and reset it with thermo dob.sided tape, since it was only touching 2 of the chips on the ecs
    I would say, get the the 125 /180 amp + prog card ecs
    http://www.hobbyking.com/hobbyking/s...idProduct=8937
    Leave a comment:
  • ket2175
    replied
    Ok noted thanks maxmekker. Btw have u heard or use before Birdy boat esc from Hobbyking?
    Leave a comment:
  • maxmekker
    replied
    Well, I would say, get a 125/ ore 180 amp hobbyking esc asap.( the 180 is big,and a tight fit in the hull) but on stock electronic , 4s is more than enough I would say. I burned the ecs on 5s with a prather 215.
    Here all stock with 4s+ prather 215 prop.
    here stock with 4s first and then on 5s, all stock(prather 215)
    and here, typhoon 500+turnigy 180 amp esc , first 4s and then 5s
    Leave a comment:
  • ket2175
    replied
    Lipo for stock 50amp esc
    Hi newbie here , just got myself a Surge Crusher, everything is still stock. May like to ask , how many mah lipo is more than enough to power this boat.
    Cause I plan to use 30c two 2s lipo 4000mah? Is 4000mah more than enough. My main point is not to burn or overstress the esc.
    Cause some members here say running on 3300 mah 30c two 2S, after a full run the esc and motor is pretty hot.
    Thanks
    Ket2175
    Leave a comment:
  • maxmekker
    replied
    Will do m8, thanks. I had 11,25 today.
    Is there a guide somewhere to tell timing on different motors( and what type of motor likes high/low timing ,like you say ,it's an 8 pole motor )
    thanks
    Leave a comment:
  • FighterCat57
    replied
    Originally posted by maxmekker View Post
    Well, first run after winter for me. One run with 2x 2s and a couple of run's with 5s setup(3+2 s)
    I got the 180 esc and a Turnigy 500 outrunner 1600KV. I would like to get some timing recommendation's for this motor. It got hot with the 5s run's. Like to hot to touch the first 5 mins and nice and fingerwarming the next 5.
    Thanks.
    Set your timing up. It will get hot with low timing. Advance it to 15 at minimum. It's an 8 pole motor. =)
    I run one in a 24" mono on 6s and doesn't get hot, just warm.
    Leave a comment:
  • maxmekker
    replied
    Timing help
    Thanks.
    Leave a comment:
  • maxmekker
    replied
    Well so much for waiting untill spring. I went with the 180 amp turnigy and the typhoon 500 motor last night.
    Let's hope it's here before the temp gets below zero.
    Leave a comment:
  • Jacked1
    replied
    It fits perfectly! i was planning to run it on 8s and a turnigy 100amp hv esc BUT the esc gets out of sync with the motor and i was pretty mad about it! so i went with a 120amp aquastar and huge prop on 6s.
    Leave a comment:
  • hpipro4
    replied
    Originally posted by Jacked1 View Post
    Yea my typhoon felt like it was sitting in the sun for a half hour after a 7min WOT run. Not very warm without water cooling. But that was the 1100kv version.
    the typhoon 600h fits on the stock mount good or what? i noticed its abit bigger in diameter than the 500h so i didnt get it.
    Leave a comment:
  • Jacked1
    replied
    Leave a comment:
  • hpipro4
    replied
    Yeah, seems like a nice combo. But that's next year for me, If I still have the hull :-).
    But what cooler to go with the typhoon? anything to recommend, that will fit.
    And Is it (the typhoon)bigger ore smaller than the stock motor.
    And for prop, as I said before, the stock setup I have now with the Prather 215 prop that came with the boat, it's getting good speed and heat is not an issue at all.
    But I would like to get some other prop recommandation's.
    I got 1 3s 4000 packs on the way,to try out a 5s settup and also some 2s nanotech packs to try out. I feel like there is more rpm to get out of the motor.
    you dont really need a cooler for the typhoon bc remember its an out runner but im running this http://www.r2hobbies.com/eng/proddet...od=rcbp1814011 stock is just fine tho.
    heres more info on the motor. tested it with the turnigy kv/rpm meter
    32k rpm @ 1900kv no load on 2x 4s wired in parallel
    noticed running two 4s wired in parallel cause the boat to flip easier bc flipped the boat 1st time wit that setup.
    yea stock prop is really good but i've tried octura x440 3blade prop works awesome!
    Leave a comment:
  • maxmekker
    replied
    Leave a comment:
  • hpipro4
    replied
    So much more space to work in you're hpi. My hatch is so narrow. se post:
    http://forums.offshoreelectrics.com/...&postcount=235
    It seems my motor sit's high to. I would like to get the Turnigy H500 motor, but would i need a new motor mount to. And cooling, anything to recommend there? for the motor ?
    yea noticed you have a different surge!
    the typhoon 1800kv outrunner motor im running is actually really good combination with the turnigy 180amp esc...i noticed they only get warm not even hot!!...love the setup just need to buy another 3/16 shaft and find the right prop.
    Leave a comment:
