Fiberglass or Carbon Fiber?
    • 9481
    Originally posted by Gerwin Brommer View Post
    Westbeach is right !
    No matter what you try, epoxy does NOT stick to abs.
    Using CA helps to let the CF stay in place, but you need epoxy to make the cf solid.
    In fact you're making a "hard skin" inside the abs hull.
    Unless : use a brush and "paint" the whole inside of the hull with CA.
    That leaves a nice surface for the epoxy to stick.....................
    yes hello!
    scuff the abs, use CA to hold the CF, then use an epoxy on top of that..
    • G Doggett
      • 477
      The guys are right, the only thing that will stick to ABS long term is CA.
      Check with Randy at BBS.
      You need to completely cover the inside of your hull with CA using a brush, and then lay the carbon fibre inside. Make sure you press it down to make full contact and let it cure.
      If some areas don't seem to have been glued properly flow some CA onto the carbon fibre so that it will flow through down to the ABS and again press it down until cured.
      It's a bitch of a job, you will glue your fingers to the hull several times and the fumes will make your eyes water !
      Finally when it has all cured, brush on a thin layer of polyester or epoxy to stiffen the carbon fibre.
      Bingo - you now have carbon fibre hull with an ABS skin on the outside !
      Graham.
      • NitroVal
        • Jun 2009
        • 423
        I dont know why, but I totally missed the ABS part in the first post
        The RTR Nightmare- Electric King of Shaves
        Now with 540s- 62mph
        New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
          • 9481
          CA on the fingers, not fun..
          • norbique
            • 367
            I agree, not to hijack the thread but what are you using to get CA off your skin?!
            Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
            - Mark Twain
            • Rumdog
              • 6667
              Acetone woks well. Nail polish remover.
              • norbique
                • 367
                thanks!
                - Mark Twain
                • boater76
                  • 574
                  Ok. So use Ca or an adhesive to apply the cf at first then when that is done drying use epoxy to coat the cf and you have the stiffness then. Correct?
                  Ken
                  • Himalaya
                    • Apr 2009
                    • 259
                    Another factor to consider: hidden antenna.
                    With FG hulls your boat can have no visible antenna if you use a 2.4G radio. That is not possible for carbon fiber hulls for its electrically conductive and thus shielding.
                    Also GPS is hard for a full carbon hull.
                      • 9481
                      What!
                      how about Kevlar?
                      • Rumdog
                        • 6667
                        I have had 0 issues with my tactic 2.4 ghz system in CF reinforced hulls. A full carbon hull may be a different story.
                        • Gerwin Brommer
                          • Dec 2008
                          • 928
                          Kevlar is even better ! ( IF you have a kevlar-scissor !! )
                          • boater76
                            • 574
                            I can use denatured alcohol to thin the expoxy out to flow better right?
                            • sailr
                              • 7128
                              lots of misinformation floating around in this thread! Jeeez.
                              Mini Cat Racing USA
                              www.minicatracingusa.com
                              • wolf IV
                                • 1050
                                http://www.youtube.com/watch?v=e-npTLBHefY
