Fiberglass or Carbon Fiber?
  • boater76
    • 505
    I've got an abs hydro I wan't to strengthen a bit, but not sure what to use.
    Ken
  • NitroVal
    • Jun 2009
    • 423
    Carbon fiber is way stronger and lighter than fiberglass. Use it whenever possible. Price is the only drawback
    The RTR Nightmare- Electric King of Shaves
    Now with 540s- 62mph
    New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
    • boater76
      • 505
      What do you use to glue it?
      Ken
      • NitroVal
        • Jun 2009
        • 423
        You can use pretty much any type of resin or epoxy..
        Shoot these guys and email http://www.shopmaninc.com/index.html
        • westbeach
          OSE Rocks!
          • 951
          Sorry, but i beg to differ! You can't use any sort of resin or epoxy to to mat down your CF or FG sheets to an ABS hull. It won't stick no matter how much you scuff up that hull. You need to use CA and mat down the cloth with some 3M Spray adheasive.
          HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
          • NitroVal
            • Jun 2009
            • 423
            I stand corrected then. I was under the impression if you used epoxy in a thin enough state, it will seep through the weaves and bond the same as fiberglass.
              • 9479
              Uh, spray adheasive?
              spray adheasive will flex
              epoxy would be a better choice IMO
              • westbeach
                OSE Rocks!
                • 951
                3M Super 77 spray adheasive! What are you talking about? Spray adheasive will flex?? Your hull is the one flexing. Your reinforcing it to stop or minimize the flexing. Suit yourself, try whatever you want Just giving you advice on the proven methods. But if your insistent on using epoxy then why did you ask??
                  • 9479
                  Dude chill out, this is an open forum...
                  • westbeach
                    OSE Rocks!
                    • 951
                    Dude, If I chilled out even more, I'd be an Eskimo!
                      • 9479
                      You need an epoxy or resin to cause the CF to become rigid and strong
                      3m will stay flex able and so will the CF..
                      we add Glass or CF to help make the boat rigid and stronger
                      • westbeach
                        OSE Rocks!
                        • 951
                        Seriously, please ask Randy at BBY racing. Or go to his website. And look under his forum, he has done a thread on reinforcing ABS hulls. Epoxy will not stick to ABS.
                          • 9479
                          220 grit works
                          • westbeach
                            OSE Rocks!
                            • 951
                            • Gerwin Brommer
                              • Dec 2008
                              • 918
                              Westbeach is right !
                              No matter what you try, epoxy does NOT stick to abs.
                              Using CA helps to let the CF stay in place, but you need epoxy to make the cf solid.
                              In fact you're making a "hard skin" inside the abs hull.
                              Unless : use a brush and "paint" the whole inside of the hull with CA.
                              That leaves a nice surface for the epoxy to stick.....................
