Leopard upgrade from UL-1?
  • don ferrette
    • 1252
    Originally posted by HOTWATER View Post
    Leo 2860 2Y....?
    Why would you go down from a 36mm diameter can? That's why I looking at the 3650's.
    - IMPBA Hall of Fame -
    - IMPBA Hydro Technical Director -
    • HOTWATER
      • 2419
      I hear ya, but then why would you want to go full P power with a UL-1 esc? You don't need to stay "limited"...just sayin'
      "Will race for cookies!"
      IMPBA D12
      • don ferrette
        • 1252
        Already have the esc's
        • HOTWATER
          • 2419
          Are we talkin' JAE? Was not sure what the hull size is....?
          IMPBA D12
          • don ferrette
            • 1252
            Are we talkin' JAE? Was not sure......
            Basically yes.
            • HOTWATER
              • 2419
              I believe the AC SV 27 (Blue can) 36/56 1700kv will pull a larger prop than the UL-1 2030 motor will.....
              IMPBA D12
              • monojeff
                • Nov 2010
                • 2728
                I would not say the blue can pull that much larger a prop unless you want to burn it up.
                My blue can was run in a 1/10 scale and didn't last the season but did get some great runs on it.
                Only saw about a 2mph difference by using it over a lower kv proboat motor.
                The UL1 motor will pull a decent prop with the right setup.
                Interest thread.
                I think it boils down to boat and speed your looking to achieve.
                Not all boats like same prop and kv....
                OSE GIFTING ELF
                HAPPY HOLIDAYS!!
                • RaceMechaniX
                  • 3024
                  Don,
                  In all honesty the UL-1 esc is best left to low wattage applications like the the 1800 and 2030 AQ motors. If you are really want to use one, look for a motor that will pull no more than a 1000W loaded. 2900KV is on the upper end for most 4S applications and a small kiss of extra cup will push amperages beyond what the AQ esc will handle. I would shoot for 2000-2200 kv range and be very careful on props if you wanted to stick with the AQ esc.
                  TG
                  Tyler Garrard
                  NAMBA 639/IMPBA 20525
                  T-Hydro @ 142.94mph former WR
