Looking at the possibility of dropping a Leopard #3650 2930kv in place of a 2030kv UL-1 for a full P power upgrade. What's the scoop on the Leopard motors and would it be too much for the UL-1 controller?? I know they're "rated" for 60 amps continuous but inside word is they are more robust than Aquacraft lets on........
Leopard upgrade from UL-1?
Tags: None
My UL-1 controller has seen 110 amps logged many times on SAW runs, 70+ average for about 3:00 runs or so. Different boats, both cats.
It has also been run with a 1512 1800kv, that's what beat the crap out of a motley crew. Didn't have the logger back then. Surprised it survived that actually, was during my first summer running electric, didn't really have a clue what I was doing!
It does have an extra cap added, just ran it across the power leads as close to the esc as possible.If my boats upside down then who owns the one I thought I was driving the last two laps?
2930kv is a hell of a lot of revs on 4s. I think it will draw more than the ESC can handle unless you prop down a lot. With the original prop, I don't think that the motor will last too long either.See the danger. THEN DO IT ANYWAY!!!
Don't think Don is talking about using it in a UL-1 hull...more or less just wanting to know if the UL-1 ESC will handle the Leopard's amp draw...Originally posted by Heaving Earth View PostIt ain't the esc you should worry about. The hull won't handle any more speed.
Don...what are you running? Hull? One of KP's props?
Correct. Ken you know me well enough to know what type of hull it is.Originally posted by HOTWATER View PostDon't think Don is talking about using it in a UL-1 hull...more or less just wanting to know if the UL-1 ESC will handle the Leopard's amp draw...
- IMPBA Hall of Fame -
- IMPBA Hydro Technical Director -
Anybody ever wire two UL-1 esc's together like Castle does with the Hydra 120's (to make 240's) ?? Hmmm...
That would get it done Don....
I'm on that page too...Originally posted by don ferrette View PostFWIW if we were talking about upgrading a UL-1 hull I'd go with an ML Boatworks GP hull over the PT hull without hesitation.
Works out to about 39k rpm loaded.Originally posted by 785boats View Post2930kv is a hell of a lot of revs on 4s. I think it will draw more than the ESC can handle unless you prop down a lot. With the original prop, I don't think that the motor will last too long either.- IMPBA Hall of Fame -
Swordfish 120+ esc......200+ to be on the really safe side....
Leo 2860 2Y....?
