Swordfish esc
    Originally posted by rickwess View Post
    If you purchased it recently, you probably do. The 220+ I purchased from OSE in Nov'13 needed to be updated, but the 220+ I purchased from OSE in Feb'14 was already at the latest release.
    I know you were on the fence about trying the Swordfish ESC. What do you think of it compared to the SK180?
    Yes, I bought it VERY recently! This is my first Swordfish ESC.
    You know, I was prompted by someone ( may be it was you) that the throttle input would be a bit more smooth if it is set at "slow or soft" start, which is exactly what I did, and so I did not feel any perceptible difference today. With all the talk of blowing up even before hitting the water , I was too preoccupied to filter any differences.
    I was seriously thinking of modifying the cooling nipple orientation of the SK 180a ESC so that it will fit in the rigger, but laziness wins once more!
    • Engelkefarm
      • Jul 2013
      • 131
      #62
      What can handle more power a 200 amp esc or a 220 esc?
      • Engelkefarm
        • Jul 2013
        • 131
        #63
        Swordfish esc im talking about. The 220a can handle 6 cell but the 200a can handle 8 cell. Someone please explain how a lower amp esc can handle more voltage. I asked the owner of ose the best answer he gave me was thats how they are designed
        • rickwess
          • Apr 2013
          • 777
          #64
          watt = amp × volt
          Assuming the wattage remains constant, if the amperage is lower the voltage can be higher.
          • Engelkefarm
            • Jul 2013
            • 131
            #65
            So between the two esc stated above which would be the better of the two on 11.1 volt
            • Engelkefarm
              • Jul 2013
              • 131
              #66
              Sorry 22.2 volt 1600kv 4082 leopard
              • T.S.Davis
                • 6266
                #67
                Originally posted by wiljm View Post
                I think I used this video from OSE as an example when I did mine.
                Does anyone know of a similar video while using a BEC on a spektrum? Tricky because you have to wait for the BEC to power the RX. Then there are maybe 3 seconds waiting on the radio sinc.................now what? The speedo is in what state at this point?
                Noisy person
                • Rocstar
                  Joel Mertz
                  • 1536
                  #68
                  Same process Terry. I calibrate mine when using the internal BEC and DX4S without issue. I know what you mean about the delay, but it doesn't effect the calibration.
                  • rickwess
                    • Apr 2013
                    • 777
                    #69
                    Never had to do that yet, but I will with the Scarab. Never thought about it until now, but perhaps use a cheapo battery holder to make an RX pack just for calibrating.
                    • pescador
                      • 503
                      #70
                      Sir!
                      Worked like magic!! I am so near sighted that I guess I had set my screen a bit bigger, I guess that is what Steven meant by resizing, too, I just thought it was a resolution issue.
                      Thank you again for all your time! Have a great rest od the day!
                      This Forum IS THE BEST!!
                      It's an older thread but I was pulling my hair out until I found this solution. Thank You, Thank You, Thank You!
                      Namba District 16
                      1/8 Miss U.S., 1/8 59 Maverick, 1/8 Executone, 1/8 Smokin Joes, MLGSX380, AC Pro40II Q Sport, AC Pro40II nitro,Twincraft mono 10s, Vision AOPC, VS1 FE, M34.
                      • monojeff
                        • Nov 2010
                        • 2728
                        #71
                        If your window looks like the following, I was able to re-create your issue. Go to control panel then choose "display". Set the magnification to "Smaller - 100% (default)", click apply, then either log off and log back on, or reboot. It will make things much smaller, but will allow you to use the program.
                        [ATTACH=CONFIG]117270[/ATTACH][ATTACH=CONFIG]117271[/ATTACH]
                        Reviving this as it saved me thank you!!
                        OSE GIFTING ELF
                        HAPPY HOLIDAYS!!
