Swordfish esc
  • wiljm
    • Aug 2013
    • 40
    #31
    You shouldn't have to change any of the options on the port. Going to device manager will just let you know what com port it is. Next to the device listed in device manager it will say "COMX" X being the number 1,2,3,4,etc. When you open the program, there's a button in the bottom left that says "Set com port" click on that, then click on the drop down and choose the com port you found in device manger. Then you should be able to click open device in the bottom left corner. Maybe I misunderstood your problem.
      My problem is that I don't see anything below the black border under the picture of the fighter jet.
      Neither "set com port" nor "open device" appear in the picture. I resized my screen but I doubt that was it, because all this time I was able to see the entire picture plus left over real estate on the screen.
        Oh, BTW, the "ready" and the clock appears though! CLOCK is running correctly!
        • wiljm
          • Aug 2013
          • 40
          #34
          I just tried setting the resolution on my laptop as low as it goes (800X600) and I still see everything fine. If you're seeing real estate outside the window, that doesn't sound like resolution is too low. It sounds like the window is too small. Is the window maximized? The easiest way to maximize a window is probably to click on the middle button, to the left of the X button, in the top right corner of the window.
          Otherwise, there should be 3 little diagonal lines in the bottom right corner of the window. When you hover your mouse curser over them, it changes into a double arrow. Click and drag the corner of the window down and over to make it bigger.
            Yeah, I maximized the window, no dice.
            I see the bottom , even the "exit" button, the clock, ready, everything on the lowest of the picture I see, just not the Open device.
              My Bad, don't see "EXIT"
              • wiljm
                • Aug 2013
                • 40
                #37
                If your window looks like the following, I was able to re-create your issue. Go to control panel then choose "display". Set the magnification to "Smaller - 100% (default)", click apply, then either log off and log back on, or reboot. It will make things much smaller, but will allow you to use the program.
                  Sir!
                  Worked like magic!! I am so near sighted that I guess I had set my screen a bit bigger, I guess that is what Steven meant by resizing, too, I just thought it was a resolution issue.
                  Thank you again for all your time! Have a great rest od the day!
                  This Forum IS THE BEST!!
                  • wiljm
                    • Aug 2013
                    • 40
                    #39
                    You're very welcome. What goes around, comes around. This was my first post here after my very fist run on my first boat. I recognized your avatar...
                    http://forums.offshoreelectrics.com/...ht=#post524278
                      You have spent much more time to help me and that is generosity on your part with your own time, thanks again, much appreciated!
                      • Alexgar
                        • Aug 2009
                        • 3701
                        #41
                        Sir!
                        glad to see it all worked out
                          @ Alexgar
                          @Rocstar
                          @Engelkefarm
                          Thanks to each one of you whose advice and help are greatly appreciated!
                          I was about to give up that very first day were it not for you guys' input!
                          and happy boating my friends!
                          • Engelkefarm
                            • Jul 2013
                            • 131
                            #43
                            I did not do much but fyi my swordfish blew up first day. My seaking 180 never gave me any issues i thought i was upgrading be carefull
                              Thanks for the heads up, wish me luck, I put it in a Zippkits JAE 21 FE rigger, hope it will be ok, I don't know....
                              May I ask which Swordfish ESC were you using?
                              • Engelkefarm
                                • Jul 2013
                                • 131
                                #45
                                220a im thinking it was defective
