It was solved, I'm still trying to set the correct trims to acheive full rpm at full throttle by matching the data logging
Even though its solved for the most part and finally calibrated -- I still notice that each ESC seems to take turns spinning at 10% - 15% throttle blips... It's not a big deal. It's just strange. I assume this is the "castle issue" Tyler mentioned where each castle ESC seem to vary when used for twins.
It's as if throttle signal slightly varies for both ESC's even tho its connected to the same Y cable.
I'm sure it'll run fine now on the water once it gets going and won't cause the torque roll flips I experienced when previously.
Torque Roll with a twin when turning at speed.
If you have your props turning inbound, you will have problems turning at speed.
When you turn the outside motor loads up in a turn, and the torque of that motor is now trying to rotate the boat even more to the outside, causing a flip.
This is why I run my props outbound on my twin race Cat, when the outside motor loads up in a turn, the torque of that motor is now trying to hold the boat flat on the water.
I have found that I can now turn at almost full speed. My "Q" Cat runs at a full speed of 70MPH.
The top speed of the boat would be a bit faster with inbound props in a straight line, but cannot turn without slowing down (FLIP)
and I do understand what you're saying but this was not the case
Just trying to get the TX to get to full throttle -- the maximum "Throttle In" I'm getting from data logs is 1.965 ms -- One of my other data logs showed Throttle In of over 2.1ms
Any of you guys have any idea of just how accurate the Castle data logging is supposed to be?
I had a separate external data logger hooked up to it complete with current and rpm sensors and all of the data in comparison compared to castle’s was about 2x higher. My data showed max of 40k rpm and 250 amps... castle showed max of 25k rpm, 40% Power Out, and 100 amps. Castle data logging was even set to record at 5x per second.
Kind of weird. Seems like some pretty useless data...
If the pole count is not correct for the motor, the rpm will be incorrect. By entering the correct pole count, the rpm shown in my Castle logs matches well with the speeds the boat is running.
Have you checked the actual amp hour usage? Time a run and see how much you put back into the packs. Compare that to what the loggers show you used. Then you’ll know.
My Castles all show virtually identical amps to what I actually used. This also means that watts are correct.
What is your exact setup?
Has anyone found a good place to buy the 1/8" aluminum extrusion from besides the one that Brian posted? They want $35 to ship a 4' piece...kinda pricey. I have an Edge 200 lite and would like to water cool it asap.
I’ll look to see if I have any spares. I had a bunch made.
Shawn
You don’t necessarily need those particular extrusions. You can make (bend) some L shapes with thin copper or aluminum and use Arctic Silver epoxy (amazon) to glue 1-2 tubes on each side. If you have the original aluminum heat sinks that came with the Phoenix edge 200 — you can simply glue tubes direct on it.
Yeah I see that they changed the design of the ESC and put added a large aluminum plate to them. If I remember correctly when they first came out with the ICE lite series they were only rated at 6s and now they are rated at 8s like the regular version. I wonder if adding that plate added enough cooling to rate them a bit higher? Looks like with the new plate I will just be able to add tubes to that and call it a day. Hopefully its enough to provide the proper cooling?
