Using a Castle ICE Aircraft Controller in FE boats
    • 7651
    Originally posted by racerr73 View Post
    Jay,
    Is there a way to waterproof the ICE 200 green heat sink version ESC as in the first pic of this thread with the fan attached.
    P.S. Where do you buy the motor mounts for the longer neu motors as seen in the first pic.
    Thanks
    Trev
    Mount looks like a Williams. Can no longer get them.
    • Darin Jordan
      • 8332
      When I build my ICE controllers, I use a Silicone Based Conformal Coating on all the electronic parts. Seems to work fine thus far.
      Darin E. Jordan - Renton, WA
      • Joe Ford
        • Apr 2008
        • 101
        Remember that you will lose your warranty with the water cooled version. Let me know if you have questions.
        Gentlemen...one correction to this. If you use an airplane controller in a boat application is does not matter if you water cool it or not, you WILL void your warranty. I just want to make this clear to EVERYONE. We will not warranty any air OR car ESCs used in boat applications. I am in the same "boat" as you with regard to this being a boat enthusiast myself. Unfortunately, we will not be producing any further marine controllers, and cannot offer any assistance in modification or give advice. You can do what you wish, but I need to make it clear to everyone that Castle's policy is that if you run any controller outside of its intended purpose the warranty is null and void, and you are all running at your own risk. Now, to end on a lighter note, should any of you experience a failure on your air/car unit while being used in a boat you are still welcome to send it in for non-warranty replacement. Non-warranty replacement costs can be found here. http://www.castlecreations.com/support/repairs.html
        Have fun and keep on boating!
        Joe Ford
        Product Specialist/Surface Team Manager
        Castle Creations
          • 9438
          I have never expected warranty on an esc unless it was DOA on first power up and test before any mods. All is good.
          • RandyatBBY
            • 3915
            Hi Joe, I have some older Castle 240 LV I wish there was some one that could repair them. Schultz still work on his old ESC. Is it possible to have some one at Castle do the same?
            I have found that the Conformal Coating needs to be reapplied every year it gets old and leaks.
            Randy
            BBY Racing
              • 9438
              From heating and cooling.
              • Joe Ford
                • Apr 2008
                • 101
                Yes, by all means send it in to us. If we can repair it, we will. If not, we'll let you know and send it back to you.
                Joe Ford
                Castle Creations
                • Joe Ford
                  • Apr 2008
                  • 101
                  The key there you already stated, but I must emphasize this. Do ALL testing on the bench before any mods are done and installed in the boat. Plug in to your rx, plug in your motor, plug in the battery, and pull the trigger. If it fails we will handle those under warranty. After mods, if it blows on first plug in, unfortunately it would be non-warranty.
                  Joe Ford
                  Castle Creations
                    • 7990
                    Thanks a lot for the clarification Joe! Yes, if you read the warranty it does state it must be used as intended.
                    • properchopper
                      rcgoatbuild@snotmail.com
                      • 6958
                      Thanks John
                      What is the difference between these two??
                      Corrosion X : http://www.corrosionxproducts.com/
                      And what I have, the original from 10 years ago Corrosion Block: http://www.blockcorrosion.com/aboutus.sc
                      I apologize for going off topic but to answer Ray's question :
                      CorrosionX HD is just a stickier/gummier version of regular CorrosionX
                      Regular
                      Flash Point 269.6 F deg.
                      Boiling point 392 F deg.
                      Dialectric strength 39,000V
                      HD
                      Boiling Point 410 F deg.
                      Dialectric Strength 20,000V
                        • 9438
                        Thx Tony
                        • RandyatBBY
                          • 3915
                          Thank you Joe. I have three CC 240 LV and two older Barracuda's. I will see if I can follow the instructions. :-)
                          Randy
                          BBY Racing
                          • Joe Ford
                            • Apr 2008
                            • 101
                            We'll do our best to get them back up and running for you Randy. :) As the repair section doesn't contain any marine controllers anymore, just send them in with a hand written note stating what you have included in the package, your full name, return mailing address, email, and phone number. Also, please include a description of what happened (if you can rememember)...this will help our techs narrow down the possible issue. For example: "The boat was running and then just shut down", or "Wouldn't arm/make tones on plug in", etc. Thanks!
                            Joe Ford
                            Castle Creations
                            • RandyatBBY
                              • 3915
                              Will do thanks Joe.
                              Randy
                              BBY Racing
                              • olwarbirds
                                Magic Smoke Wizard
                                • Oct 2012
                                • 1136
                                I have a castle phoenix 200 thats been converted to watercooling etc...problem I'm having is getting it to arm. I'm using a Spek DX3C xmttr and a Spek MR200 rcvr. I know everything is working because the servo works, but the motor keeps beeping and the esc has a red flashing light. I have no doubt its something in programming or epa. Can these Esc's be used without a pistix ? I have the esc programmed for auto epa... help ... DJ
