Doby's New Cat Spring/ Summer Build
  • bustitup
    • 3072
    #76
    Is that a plastic prop k series?
    How were temps?
    Have you tried a k47/3?
    I would be carefull propping up with that esc (heat)
      • 7512
      #77
      Yup;http://www.offshoreelectrics.com/pro...od=grp-2317.51
      Will try this one next; http://www.offshoreelectrics.com/pro...od=grp-2317.54
      The temps were,,,,motor 109, controller 98 and batts around 90.
      No
      I'm also slowly adjusting the strut height upwards after each run,,,,reducing the load on the motor.
      • bustitup
        • 3072
        #78
        couple more questions Doby
        you used that double rudder that has a 1/4" strut ...how are you using k series props?...did you get a step down prop shaft to 3/16"
        also how do you like the way she turns with the double rudder system...would you still go the same way?
        • bustitup
          • 3072
          #79
          I sent u a pm for the rudder
          Originally posted by Meniscus View Post
          Considering you're looking at $63 shipped for the dual rudder, I sent you a PM with another source Same rudder and available in blue as well.
          If anyone else is looking for this rudder, please PM me.
            • 7512
            #80
            Yup, OSE has them.
            The way its handeling, I'd use it again in a second
            • bustitup
              • 3072
              #81
              any more updates here?
              • bustitup
                • 3072
                #82
                bump
