Mhz mystic 114 build
  • BUMBLESPECIMOODA
    • Feb 2023
    • 255
    #31
    Originally posted by PlayerUnknown069 View Post
    What servo and servo horn setup are you planning on?
    I see people saying the offset servo horn is best like the one from custom carbon fiber parts. Not who else sells one like that.
    I don't trust the tiller-arm locations, that are not in-line with the pivot. Hence my making of the rudder blade grip.
    I'm using a black aluminum fut25t servo horn.
    Faux hydraulic rams will be used.
    Countersunk bolts arrived. Rudder done:
      • 4335
      #32
      It's best to keep everything linear and the attachment points inline with the pivot at both the rudder and servo. Makes life so much easier.
      • BUMBLESPECIMOODA
        • Feb 2023
        • 255
        #33
        I want flush fasteners on the rudder blade-grip, so I turned down some flanged nuts, to suit my tastes:
        • PlayerUnknown069
          • Apr 2023
          • 72
          #34
          Looks clean. Anyone know the spacing between the rudder pivot points on the stock mounts? MHZ does not specify and I want to order a servo and servo horn for it.
          • BUMBLESPECIMOODA
            • Feb 2023
            • 255
            #35
            Do you mean the distance of the tiller-arm holes from pivot pin? If so, I will measure them tonight after work, then let ya know.
            • PlayerUnknown069
              • Apr 2023
              • 72
              #36
              Correct, I see most in picture are using a small horn like this cheap Amazon one 3Pack ShareGoo Aluminum Alloy 25T Servo Horn Double Arm Steering Arms Compatible with Futaba Savox Power HD HSP MG995 Servos Motor 1/8 1/10 RC Car Buggies (Red) https://a.co/d/dIHTr1c
              I just want to confirm before I go buying anything.
                • 4335
                #37
                [ATTACH=CONFIG]178513[/ATTACH] [ATTACH=CONFIG]178514[/ATTACH] [ATTACH=CONFIG]178515[/ATTACH]
                Ha, I've never thought of doing that. Great Idea. What did you use to make your counter sink holes in the carbon? I used some cheap habor freight drill style bits for wood, but they dulled after a single hole. I need to find an aggressive cone shaped bit for my mill.
                • BUMBLESPECIMOODA
                  • Feb 2023
                  • 255
                  #38
                  One of my best tools. Carbide multi-fluted counter sinking bit. Made in Chine off of Ebay. It's now slightly dull after about 15-years of use.
                  I have it in a Hudy handle, and turn it by hand.
                  • Alfa Spirit
                    • 2131
                    #39
                    What is this exactly ?
                      • 4335
                      #40
                      Scale replicas of engine exhaust headers
                      • PlayerUnknown069
                        • Apr 2023
                        • 72
                        #41
                        How’s the build coming along?
                        • BUMBLESPECIMOODA
                          • Feb 2023
                          • 255
                          #42
                          It's coming. Did some reinforcing in the hull & deck today. Thickening up stress-areas and bad lay-up sections. Rough areas were mudded, and will be sanded to make a refined surface, as well as feathering out of the seam edge. Then, 1-layer 6oz. carbon cloth will cover the entire inside.
                          While the hull & deck are apart, I'll be rigging it. So much easier like that. Reminds me of my full scale boat building days, crane-lowering the engines in place etc.
                          Just had the angle-grinder out:
                          • BUMBLESPECIMOODA
                            • Feb 2023
                            • 255
                            #43
                            I used these:
                            PM me with your address, and I'll mail one out to ya, if ya want.
                            • PlayerUnknown069
                              • Apr 2023
                              • 72
                              #44
                              I used these:
                              I appreciate the offer but it would cost us more in shipping than me just ordering it on Amazon. Canada to South Florida isn’t cheap. I ask because I see most of the fancy mystic builds use the CCFP servo horn which looks nice. I want to avoid cable slack when in turns. Also Oxidean sells a cheaper version: https://www.ebay.com/itm/22545883823...mis&media=COPY
                              • PlayerUnknown069
                                • Apr 2023
                                • 72
                                #45
                                [ATTACH=CONFIG]178543[/ATTACH] [ATTACH=CONFIG]178544[/ATTACH]
                                [ATTACH=CONFIG]178542[/ATTACH]
                                Hulls looking really good, you are invested at this point since you sliced it open. I see not short cuts being taken, you are doing the right thing. I really hope I don’t have a similar issue with my assembled 114. With a 3 month old baby I just don’t have the time to do that kind of work. I don’t like to half a** anything and I knew building a bare hull would just send me down the quest for perfection rabbit hole. Any free time I have needs to be spent on the water at this point in my life.
