Mhz mystic 114 build
  • PlayerUnknown069
    • Apr 2023
    • 72
    Yeah I’m pushing for 100mph in cat. What motors are maxing the X8s? I run an XLX2 with a single TP4060 in my 34” Carbon mono. The motor pulls 300amps easy but that’s a mono. I was hoping the X8 was enough for a cat with lower resistance on the water. I’m running 2 Leo 4092’s 2080kv.
    • vvviivvv
      • 1100
      1950 Lehners with a high KV on 6s.
      It's a proper SAW (2 pass and done) boat
      Uk SAW record holder
      • vvviivvv
        • 1100
        I have 2250/7 in my Hpr's and that's about 120mph depending on props on 8s
        • BUMBLESPECIMOODA
          • Feb 2023
          • 255
          I'm planning on SSS 4092-V2'S and CASTLE CREATIONS HYDRA XLX2'S.
          • PlayerUnknown069
            • Apr 2023
            • 72
            XLX2 is on sale for $277 on Amazon, X is $269.. the question is not about cost, I am thinking about being heavy with two of those massive XLX lol
            • BUMBLESPECIMOODA
              • Feb 2023
              • 255
              They are big. I'll really look at alternatives when ESC time comes.
              For now, got the bandit mask done:
              • BUMBLESPECIMOODA
                • Feb 2023
                • 255
                Pipes
                Also got some pipes made up:
                Working on this today:
                  • 4335
                  That rudder mount looks awesome. Nice work on the hardware countersinks
                    • 7651
                    Really nice looking gear
                    • PlayerUnknown069
                      • Apr 2023
                      • 72
                      Really nice rudder hardware. Are you hand cutting the carbon? Because it looks super clean cut. I wonder if I can cut carbon on my C02 laser.
                      • BUMBLESPECIMOODA
                        • Feb 2023
                        • 255
                        Yes, hand-shaped. Dremel, files, sand-papers, & pain.
                        • BUMBLESPECIMOODA
                          • Feb 2023
                          • 255
                          Did this today. When all parts are finished, the carbon bits will be clear-coated, the alu bits polished, and countersunk stainless fasteners installed.
                          Spun some threaded inserts for the canopy attaching. I tap the fiber-plate, then toothpick graphite-powdered epoxy-resin into the cut threads. Then I bolt in a waxed bolt to mold the threads. Works out very stong, and has resistance like nyloc-nuts.
                          They will be mudded & smoothed (with the rest of the messy stock lay-up), then covered in my lay-up of a layer of 6oz. carbon cloth.
                            • 7651
                            [ATTACH=CONFIG]178493[/ATTACH]
                            [ATTACH=CONFIG]178494[/ATTACH] [ATTACH=CONFIG]178495[/ATTACH] [ATTACH=CONFIG]178496[/ATTACH]
                            Well that hatch will be secure. I thread the F/G or carbon for my rudders/struts for the most part. Interesting about the final step though. Nice little trick.
                            • PlayerUnknown069
                              • Apr 2023
                              • 72
                              Those hatch locks look great.
                              • PlayerUnknown069
                                • Apr 2023
                                • 72
                                What servo and servo horn setup are you planning on?
                                I see people saying the offset servo horn is best like the one from custom carbon fiber parts. Not who else sells one like that.
