CF Rigger Build
  • Meniscus
    Refuse the box exists!
    • 3312
    #76
    Thanks for the input Apples1!
    I regret to say I don't have enough funds to afford that much motor, especially with some of my other projects. The reason why I was going with the 1107/2D is the KV vs. watts. I want to use the 2s lipos I have in parallel for the power vs. weight and still achieve appropriate rpms.
    I would entertain some other configurations, but right now, I'm trying to get this running fast without having to purchase more lipos to make it happen. I do have a 3s at 2300 mah, but I don't think that will last long under the current draw to make it go fast. Does that make sense?
    • Ub Hauled
      • 3051
      #77
      Ben, I have to say that I am not very familiarized with that motor... actually... not familiarized at all...
      • Meniscus
        • 3312
        #78
        LOL, well it sounds like I may be the guinea pig. We'll see what everyone else says.
        Does anyone run a 2s2p setup in SAWS?
        • Ub Hauled
          • 3051
          #79
          I have not seen it in hydros but in Monos I believe people have done it.
          • Meniscus
            • 3312
            #80
            Who's talking hydro? I'm talking rigger
            • Ub Hauled
              • 3051
              #81
              I meant hydro type boats... Riggers, Shovels, Pickle Forks, Cats, Tunnels...
              • Apples1
                • Dec 2007
                • 418
                #82
                I am running 2 x 2s lipos in series as well!!
                returning to boats after a big break
                • calcagno45
                  • Mar 2008
                  • 1050
                  #83
                  Apples: I think Ben is only running 7.4v's with twice the mah in his. You're running 14.8v.
                  • J Solinger
                    • Apr 2008
                    • 197
                    #84
                    Just for intrest sake, this is a hull that was made by the lost foam method. Composit materials can be purchased in tube form, more like a tube sock. The form is made of foam and the sock is pulled over and saturated with resin. This was made by Terry Keeley:
                    Joe Solinger
                    • Meniscus
                      • 3312
                      #85
                      I know UB, just giving ya a hard time.
                      Yes, that is correct.
                      So, a tube sock? I may have to test that method. I don't think I've heard of that before. Is it the same to use hose or something along those lines? Or does it have to be thick? I was just thinking of a longer format for the tub to execute this idea. And the resin dries OK?
                      • ghostofpf1
                        • 399
                        #86
                        Looks like a chinese finger puzzle....I've used it before to make a lost foam glider fuselage
                        Look towards the bottom of the page for an example...http://www.acp-composites.com/home.php?cat=251
                        HTH
                        Steve
                        • calcagno45
                          • Mar 2008
                          • 1050
                          #87
                          How do you get the foam out the tube afterwards?
                          • Meniscus
                            • 3312
                            #88
                            I think that most use gasoline, but I'm sure there are other solvents that can be used.
                            • Meniscus
                              • 3312
                              #89
                              HTH
                              Steve
                              Great link Ghost! Thanks!
                              • calcagno45
                                • Mar 2008
                                • 1050
                                #90
                                Ah, so they disapate the foam with a solvent. Smart idea. I'd like to see thise process in action.
