Common sense would indicate that the least drag would be a pickup behind and above the prop. There will still be a de minimis. amount of drag, as the prop's rooster tail would in effect be "pushing" against the pickup, but it will be minimal. If you position the pickup above the prop to capture the vertically-rising portion of the rooster tail, you may actually get a vertical component of force, producing some lift. This is probably so small, you would never notice it, but it is there nonetheless.
CF Rigger Build
I wouldn't have even realized regarding the lift! Thanks for the input. Considering the overall weight is being kept to a minimum, it may make more of a difference than with other similar setups.
What's all this talk about common sense? I'm not sure I know what that is or for that matter, what gravity is either. If I can "charge" the hull, then effectively, I can create a slipstream of electrons to reduce drag. I think the color would be aquamarine if you know what I mean and follow that stuff. LOL
I guess I'm not funny. Oh well, its not the first time that I'm not funny and won't be the last.
I'm thinking how to execute the prop wash water pickup, but I'm not a fan of how this typically looks. Does anyone have a streamlined design they wouldn't mind sharing?IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
I just didn't know if someone had some fancy design they were employing for this style pickup.IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
OK, here's the update:
Tub - Shape is done and needs covering with material
Sponsons - Need to be drilled and aligned at the correct angle
Batteries - I have qty. 2 - 2s lipos to be run in series, so = 4s
Motor - For now, I'm going with the Ammo 28-45-2700 I have. I'll probably take Dr. Jet up on his offer later, but that's TBD
Strut and Rudder Hardware - In hand and ready to go on
Driveline - Ready to go in, coupler ready
Turn Fin - Refer to other thread: http://forums.offshoreelectrics.com/...ead.php?t=5912 - user: "westbeach" is helping me out with that, you got to love this forum!
Motor Mount - need to pickup
Water Jacket for Motor - need to pickup
Prop - need to pickup and get S/B
Adjustable Sponson Mount - need to fabricate
So there's the update. I'm hoping that I will get some time next week to start checking off the list for assembly.IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
This was a Micro Iceberg. The prop is an X427.Attached FilesA nation of sheep breeds a government of wolves
I'll keep that in mind, thanks Dr. Jet. Right now, I'm leaning towards a 3-blader. But, I admit I don't have near the experience as others, so I'm going to let the more seasoned guys in the club help to steer me in the right direction.
What's the worst that could happen? I get an extra prop or two in the prop box? And before you get any ideas, my prop box consists of 4 sections, overall size measuring roughly 2" x 2" x 1"! LMAOIMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
OK, I'm back to motor options. I'm thinking about an 1107/2D, 2s2p at 7400mah. What do you guys think? Also, I can't seem to find the amp rating for this motor. Input anyone? Am I way off base?IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
Isn't anyone going to weigh in? Thanks.IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
Thanks for the link Jan. Thing is, I don't see this motor. Am I missing something?IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
oops... I could have sworn I saw it there... look here:
not much info but you can calculate what you need from the data:::::::::::::::. It's NEVER fast enough! .:::::::::::::::
Cool! It looks like I'm not too far off then. Unless...
What do you think for this build, keeping in mind it is ultralight?IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
