I am doing it. She is almost done. I placed the ESC under the radio box to lower the CG, the batteries will most likely need to be under the front deck. Moved the radio box forward, it wont be waterproof, I needed it to hold the servo. I left the trim tabs and turn fin on for now, I wasnt sure if they should come off or not. Should be finished tomarrow, i still need to run wires threw the top of the hull and make it waterproof somehow, but I may not be able to try it out I nearly blew the shaft in the outboard today.
I'll have to look when I get home) and I ground it down until it was thin enough to fit into the flats...
