SV27 W/Ouboard
  • Flyguy55
    • 218
    I raced Nitro Outboard Monos for many years . You will probably have to mount some very long trim tabs to get it stable at speed . The trim Tabs were maybe 3" long and an inch wide. It was important where they were mounted , too wide and they were out of the water when running. Also if the prop is too low it lifts the back of the hull . thats probably why its just running on the prop. Set up right you won't need to tuck it under , just like your bass boat.
    Did you lub the flex shaft each run ? There is a 90 deg bend in the flex and needs good lube.
    I have an earlier version lower unit thats open under the mounting plate. I fill the area around the coupler with a mix if 50 50 STP and a low friction motor oil. It works like an oiler during the whole run. Ive not broken a shaft in 2 years.
    You also need to lube the prop shaft where it goes through the bushing before each run , otherwise the bushing wears out quickly , wobbles , and leads to flex breakage.
    You might be able to drill a hole through the adapter so you can add oil . If you use an oil mix it also lubs the prop shaft and bushing.
    The hulls that were good O/B monos had a farly wide beam.
    Sanding and polishing the flex shaft before instaling it helps to. make it as smoth as possible , remember its a long shaft running in a long bushing .
    Dick Roberts
    Abq NM
    • ice329
      • 797
      Thanks for the info Dick, I apprieciate all the good info. I will readj a few things and maybe get back on the water.
      The lube I have been useing is the Grim Racer grease. I think I blew the shaft while on the TS2 when she flipped, the guy at Fullers said sometimes when your at full throtal and it reenters the water like a flip it could bust the shaft. Hopefully that is all it was.
      • Avanti
        • 1298
        Very true
        The Manx has been sitting dormant, but I think I finally have my motivation back. I hope to see it float soon.
        • ice329
          • 797
          She is a keeper. Still needs tinkering to get her racable, she is still radical but what fun to drive this bitch. One of these days I will put her up against a stock SV but I will put my dollar on the outboard if I can finish the heat...hehhe Here are a few small vids
          Now to pull it all off and get back to the TS2 and see if I can get it where I like it
          A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
          • Ocean Racer
            • 511
            that is pretty sweet. From the video it looks like it slides in the turns or is that just our point of view.
            Failure is the First step to SUCCESS
            • ice329
              • 797
              She drives completely differnt then the stock hardwere. In the second vid you see how it does turn if you want, I think what you see is the way I was driving it. I ran it at least 6 more times after the vids taken and dialed it in actually pretty good. Its just a compleatly differnt ride and I like it.
