ML Boats RSX 310
  • Moonie
    • Jan 2014
    • 342
    #76
    Hey James here you go.
    Motor- Neu 1515 1.5d 2700kv 8mm conceits on it
    Prop- modded ABC H6
    Esc- Castle xlx I mod them let me know if you need one
    Battery- thunder power 5,000 mah 55c to 70c
    Skid fin- Virginia craftsman sport 20 fin cut smaller
    Cable- 3/16 to 3/16 shaft
    Gold Spilo
    • RC boat addict
      • May 2020
      • 61
      #77
      Thank you moonie,
      What are 8mm conceits
      I have a spare 150 amp Flycolor esc they are waterproof and handle 1080 amp peaks,what amp is the xlx?
      James
      • Moonie
        • Jan 2014
        • 342
        #78
        Sorry I’m on my phone at work. 8mm connectors on the motor. Castle xlx current limit can be set to 400amps. The motor I mention is a hungry set up. Your not racing so a 150 esc could be the ticket for you.
        Gold Spilo
        • RC boat addict
          • May 2020
          • 61
          #79
          Moonie, that XLX sounds like a brute what?s the Finished weight and the cost.can it do 8 s
          ( just for future reference)
          James
            • 9438
            #80
            Originally posted by Moonie View Post
            That's a good idea. How far along are you on yours now?
            Actually I finally finished it last fall. I still haven't taken it for a spin. I have in it a Scorpion 36mm x 83mm motor, 2200Kv 1Y with a SF200 old style 2-6S Esc and 4S1P 6000Mah Hacker 100-200C lipo's they are very capable.
            I was going to try a ABC 1817 on it unless you can steer me to a different prop??
            TIA
            • Moonie
              • Jan 2014
              • 342
              #81
              I’m not sure on the weight but it’s minimum. It comes out less weight than a stock xlx. 8s it the max cell count. Right now they are $290 shipped.
              Gold Spilo
              • Moonie
                • Jan 2014
                • 342
                #82
                TIA
                Hey Ray. When you going to take her out? Show us what you have done to yours. The setup you have should be fast. I wouldn’t be surprised if you could end up using more prop.
                TIA[/QUOTE]
                Gold Spilo
