head of the river cat hull thread
  • elvish
    • 125
    #481
    I don’t think 250 amps is accurate, but still I haven’t tried it myself so I wouldn’t know
    • KillerDave
      • 370
      #482
      Wow, that is agressive modding!!!
      I'll leave it for now, probably going to change my motor for racing and just have fun with it as it is for now, but then I don't have to drive it flat out all the time???
      HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
      • KillerDave
        • 370
        #483
        Originally posted by Alfa Spirit View Post
        I think you' ve got a good setup. Mine will be :
        XPower 11 XL / 1510 RPM per Volt
        HiModel GX 200A Opto ESC
        2x 3S 5000mA/h Li-Po's
        Looking to this picture, you didn' t put carbon layer to reinforce the hull ?
        Strengthening the hull wasn't something I had considered, this is my first go at FE and I am on a steep learning curve....
        The help I have recieved has been great! Thanks to all!!!! Oh, and keep it coming!!!
        • crabstick
          • Jul 2008
          • 954
          #484
          Originally posted by ozzie-crawl View Post
          yes runs 4s, uses a mystery 200a, no water cooling just a fan
          no long run time on a setup like this 1-1.5 minutes
          a lot also depends on setup
          Missed the post on you cutting it down and detongue'in it. Much clearer now.
          Matt.
          www.rcboats.co.nz
          • Alfa Spirit
            • 2131
            #485
            Just for fun
            HM Agitator
            HOTR
              • 9438
              #486
              PPPPlease put a ruler across the sponsons of both and take a picture of it dead on from the rear.
              Would like to see difference in sponson angles.
              Please!!
              • elvish
                • 125
                #487
                it’s been posted before, there is a different angle, what’s your point?
                  • 9438
                  #488
                  Sorry, have not seen the post you refer to.
                  My point is to see the difference between the 2 before I start a build.
                  • elvish
                    • 125
                    #489
                    this is the hotr, the h&m is straight...
                      • 9438
                      #490
                      thank you thank you thank you thank you........
                      Thats alll I needed to know.
                      Well maybe one more question... please..
                      Is your HOTR hull in epoxy glass or poleyesterglass?
                      The one he sent me last year has sponsons like yours, my gelcoat sucks and looks to be polyestery glass, it's brownish on th inside.
                      • bustitup
                        • 3071
                        #491
                        Just for fun
                        HM Agitator
                        HOTR
                        you should have added the third choice and view of the new skunworks cat hull...here it is
                        SKUNKWORKS CAT
                        • Jeff Wohlt
                          • 2716
                          #492
                          You can fix those sponsons very easy with some bondo auto putty. Most of the tunnels are made just the opposite...with edges in and not out.
                          www.rcraceboat.com
                          jwohlt5362@yahoo.com
                            • 9438
                            #493
                            Me like the Skunk.
                            I put in a PM for the waiting list. I take it his sponsons aree flat like H&M or like HOTR???
                            • elvish
                              • 125
                              #494
                              Polyester glass, brownish on the inside, stinks, gel coat sucks.
                              Needs a good reinforcement, a crazy sanding, and a good painting.
                                • 9438
                                #495
                                Cool Jeff. I was toying with the idea of building them up but wasn't sure how far to go.
                                Rull on RC Univ. added quite a bit of material (D.Fir) to his sponsons but, hasn't finished his build yet.
