head of the river cat hull thread
  • Jeff Wohlt
    • 2716
    #451
    That is the dangest servo and linkage I have seen...looks pretty good.
    www.rcraceboat.com
    jwohlt5362@yahoo.com
    • domwilson
      • 4405
      #452
      Originally posted by Jeff Wohlt View Post
      I also get them from ETTI in different lengths. They are neat.
      Great decals! Did you print those on the inkjet?
      I didn't see them on your site. Do you have a price?
      Government Moto:
      • Alfa Spirit
        • 2131
        #453
        Originally posted by Alfa Spirit View Post
        I' ve got an other idea using a Graupner 3/16" drive dog, have a look and let me know what you think
        I wasn' t sure about HOTR strut and Graupner drive dog assembly but that' s OK. I need to install a tube of brass on the shaft for a perfect assembly. [ right side of the picture ]. Propeller shaft will be very well guided without axial amount of play.
        Here is the Graupner drive dog, with this one I can put all 3/16" sized propellers on 4mm shaft and propellers with M4 threaded
        Installing a brass tube 4mm inside and 5mm outside, approx. 15mm long. Like this the shaft won' t move, only a small amount of play
        • KillerDave
          • 370
          #454
          If you mean the one on my Bud' Select Boat, Thanks, I had this big strong servo and it wouldn't fit under the cover so I put it there. It work is all!!!
          HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
          • Jeff Wohlt
            • 2716
            #455
            You will see my site changing more soon. I have some goodies coming but am also losing a few...motors will probably not be there anymore and a few other items.
            These come in several lengths...I use the longest I can put on for XL and that is 60mm for .
            Yes they are $10.50. (sorry had to edit that)
            I just had to move my site to another prider...yahoo so it will be undergoing some surgery over the next week or so.
            These will be up by this evening.
            www.rcraceboat.com
            • domwilson
              • 4405
              #456
              What is your setup?
              Government Moto:
              • KillerDave
                • 370
                #457
                Originally posted by domwilson View Post
                What is your setup?
                Ok,
                Feigao 12L
                Etti Navy 125 ESC
                2x 3S 5000mAh Li-Po's (6S)
                TFL Hobby Rudder fitted with an Octura skeg
                Prop Shop 40mm prop but I don't know the pitch...????
                • domwilson
                  • 4405
                  #458
                  Wow...You're really pushing that 12L. Boat looks good. How are your temps? How long do you run it each time?
                  Government Moto:
                  • KillerDave
                    • 370
                    #459
                    This was the first time I have run it, I didn't time it I think about 8 min's??? Maybe???
                    I don't know the temp either, I have no way of measuring them??
                    One of the guys at the lake flies E-Heli's, He thinks the batteries are fine, Not too hot????
                    What motor would you have put into it?
                    • elvish
                      • 125
                      #460
                      r there numbers on the prop?
                      • KillerDave
                        • 370
                        #461
                        I was given the prop Ballanced and pollished, the numbers are all but gone...
                        • domwilson
                          • 4405
                          #462
                          I myself would have went with an 8XL or 9XL on 4S or a 11XL or 12XL on 6S.
                          But I'm a bit more cautious. But if you are doing this reliably with good temps on all your components (motor, ESC, Batteries) have fun with it. It's just not what I would run.
                          Government Moto:
                          • elvish
                            • 125
                            #463
                            a mate i run with has one with my old 7xl and a 447/3 prop i modded
                            ozzie-crawl when you get online, please give us more info on the setup, thanks
                            • KillerDave
                              • 370
                              #464
                              But I'm a bit more cautious. But if you are doing this reliably with good temps on all your components (motor, ESC, <a onMouseOver="javascript:window.status='batteries'; return true;" onMouseOut="javascript:window.status='';return true;" href="http://thebigsvc.info/?v=4%2E03&ss=batteries">Batteries</a>) have fun with it. It's just not what I would run.
                              It seems to run fine, I was just having a little fun this week, next week I'll go down to the lake and try to get one long run, I'' time it, get a GPS speed and see if I can get temps too...
                              • KillerDave
                                • 370
                                #465
                                Ok, Now I'm getting lost! This is my first FE and brushless too... Can you explain the difference against what I am running and what has been sugested?????
