head of the river cat hull thread
  • matti1983
    • Jul 2009
    • 48
    #601
    I have 7xl and i am going to buy 3S lipos so how that motor would work with 6S setup??. I am using Himodel 200A ESC.
    • ozzie-crawl
      • Sep 2008
      • 2943
      #602
      that would give you around 53,000 rpm
      i have run a 7xl on 4s and its easy to get over 50 mph with that hull
      • matti1983
        • Jul 2009
        • 48
        #603
        Yes i know that it will give almost 53 000rpm but i want to know how well motor/ESC can take those rpm:s.
        • Punisher 67
          Ignore list member #67
          • 1616
          #604
          unless you are doing a saws boat about this well..................................
          • matti1983
            • Jul 2009
            • 48
            #605
            i want it to be kind of "fun run" boat but i dont want to burn it in first runs soooo what is best motor choice with 6S? 8XL or 9XL or maybe 10XL??
              chart:
              NEW KV'S FOR FIEGAO AFTER jUNE 2009 oops caps...
              http://www.offshoreelectrics.com/conversion.htm
              12xl gives approx. 32K rpm for 22.2vdc
              • Alfa Spirit
                • 2183
                #607
                540 XL 10 to 540 XL 13 under 6S is right, approx. 33000 RPM
                • lomdel
                  • 722
                  #608
                  In my oinion and acoording to FeCalc a 12XL is the fastest sensible motor to use with 6S. I run a 13XL on 6S in my TC31 and it is fast and reliable. With 7XL on 6S your electronics won't last long Do the math : kv x Volts (anything more than 35000 rpm would be too much...
                  • matti1983
                    • Jul 2009
                    • 48
                    #609
                    How fast it is with 12XL??
                    • ozzie-crawl
                      • Sep 2008
                      • 2943
                      #610
                      dont take this to the bank as such but a 12xl on 6s with somthing like a y537 prop should see you close to mid 40s,with say 5000mah batts you should get fairly good run time.
                      if you wanted more speed later on you can prop up
                      just remember the faster you push it the less run time you get
                      • matti1983
                        • Jul 2009
                        • 48
                        #611
                        Do you have any video about this boat with 12xl+6S
                        • Christaphason
                          • Jun 2009
                          • 107
                          #612
                          Bigdg357's Hotr cat with an 8xl on 6s.
                          Its possible to do this kind of thing, but VERY risky.
                          • Alfa Spirit
                            • 2183
                            #613
                            Originally posted by Christaphason View Post
                            http://www.youtube.com/watch?v=orUlosXr5sU
                            He installed 6S batteries for the video only one run. 540 XL 12 turns is perfect
                            • Tuslow1
                              • 154
                              #614
                              I'm no pro but if it isn't a serious saw boat why deal with the headaches? In my mind the more juice you put to it the faster things will blow. ( more power more heat ) Besides, I built my HOTR Cat because it was inexpensive and nice looking plus following the setups of others it's a safe fun 50+ mph boat. Trust me a 50 mph boat will chew a nice size pond faster then you know!!! The hull looks nice but it's thin and it will not take a front-end crash because you couldn't stop it @ 60 mph. Then again what do I know take some video and lets see what happens
                              OK, You Go First!!!
                              • matti1983
                                • Jul 2009
                                • 48
                                #615
                                You have convinced me that the 7XL is too much with 6S, But what about 10xl??? is it still too much?? It gives about 38500rpm`s so it`s a pit more than 35000rpm.
