Zonda build
  • ade-rc
    • May 2017
    • 14
    Zonda build
    New to RC boats, new to this forum, so diving in with a Zonda build.
  • ade-rc
    • May 2017
    • 14
    Blank hull ordered from Hong Kong.
    Drive line mock-ups started
    • Prodrvr
      • Jul 2015
      • 701
      Question...is that motor mount going to fit in the sponson at the correct angle, or do you have to mod it?
      • Mxkid261
        • Jun 2015
        • 734
        Are you setting this up as a twin?
        • ade-rc
          • May 2017
          • 14
          It has slots in the sides so can be adjusted somewhat. But mod'ing it is also on the table.
          • ade-rc
            • May 2017
            • 14
            Yes twin, other screw is in the picture on the balancer. First ever boat build, so hopefully will be fun building and learning.
            • hughb
              • 152
              Looks really nice. All the best with you build. I have a CF Zonda too i wish to rebuild when time allows
              • ade-rc
                • May 2017
                • 14
                Thank you. Should be a fun build.
                • Beaux
                  • Dec 2015
                  • 550
                  Nice going. Good luck, there's a lot of good info on here.
                  • ade-rc
                    • May 2017
                    • 14
                    Thanks. Will probably be scanning for build info as it moves along.
                    • ade-rc
                      • May 2017
                      • 14
                      RH driveline started. Need to ream out the stinger for the stuffing tube. A bit tight and not going to force it.
                      • Prodrvr
                        • Jul 2015
                        • 701
                        Before you go reaming, what diameter are the shafts and tubes?
                        • ade-rc
                          • May 2017
                          • 14
                          Stuffing tube fitted nicely in LH. RH had burrs so reamed them out and fits perfect now. (9/32 brass for 0.187 Teflon)
                          • Beaux
                            • Dec 2015
                            • 550
                            Just checking if you got a left hand drive cable...
                            • ade-rc
                              • May 2017
                              • 14
                              Yes a LH and RH. Does anyone have estimates of length change at full RPM
