Originally posted by dmitry100
View Post
HPR 115(Average White Boat)
the worst pain in the ass to drive and handle is the HPR64.......I have driven once....never again!!!!
Well I've been 'work' busy but have been messing with the logger and the handling of the boat. My RPM reading is off, had to try a couple GPS expanders, and the voltage reading was off as well. Remedied on all counts now(i think). I do have 65MPH and all of 65 amps with the Andy Brown 447's on 5s. I am going to try my next set of props and see if my reading are good on the next run. After that I think we shall start upping the voltage.
But here is the last run: https://youtu.be/0Ywnchh7UOg
I have another spot and if I run up and down the beach at this lake(to the right in vid) there is room. I could run at a big lake too that isn’t too terribly far away.Originally posted by fweasel View PostYou're going to run out of lake quickly with that monster when the voltage goes up.
Ryan, I got out today with my set of 2114/15* rake 3 blades which Chris S&B and cut down to 47mm. It handled worse in my opinion. Those props would have more bite than the 447’s so I’m thinking there is just too much prop.Originally posted by fweasel View PostYou're going to run out of lake quickly with that monster when the voltage goes up.
Whatcha think?
I don't have enough runs under my belt to make those kind of recommendations, but it was night and day difference between props on my Genesis in terms of stability in setting up the run and rolling into the throttle. I've had luck with 3 blades on some boats, but have never been able to predict how they'll react in regards to 2 blades I had previously run. Finicky animals.Vac-U-Tug Jr (13mph)
[QUOTE=Prodrvr;727711]Have you seen all the pins in that lake? And if I could get it to launch straight maybe I’d have a chance. It’ll get there I just need time off to run it.Originally posted by srislash View PostWhatcha think?
I was waiting for you to send it...but never happened lol. Make a vid of that thing wide open instead of dicking around with it lol.
Mmm, you may be onto something here Ryan. A real gentle build in speed seems to be the ticket. I tried my 42mm 1.7 pitch 3 blades and it does handle better but no real change in getting up on plane.Originally posted by fweasel View PostI don't have enough runs under my belt to make those kind of recommendations, but it was night and day difference between props on my Genesis in terms of stability in setting up the run and rolling into the throttle. I've had luck with 3 blades on some boats, but have never been able to predict how they'll react in regards to 2 blades I had previously run. Finicky animals.
I’ll keep trying things but I wanna try the big boy props on open water.
